Kitchen Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2007, 02:24 PM   #1
Kitchen Exhaust Fan
I have a Pryne & Co "Blo-Fan" kitchen exhaust fan with three speed control......obviously very old....I searched the web for parts with no luck....just was curious if anyone was familiar with these....and if there were any parts available.....?
Thanks,
Rick
Rick Bruner is offline   Reply With Quote
Old 06-22-2007, 12:11 AM   #2
Pryne Blo Fans
I have pryne blo fans in my johns been looking for parts to no avail
My house was built in '60 Think I may start going to Demolition sales
KADUTZ is offline   Reply With Quote
Old 03-19-2009, 04:06 PM   #3
Mr Bruner,
My Pryne 210 Blo Fan just burned out ... what were your results in replacing/relocating suitable exhaust fan?
Thanks,
Mary
Mary Rochells is offline   Reply With Quote
Old 03-20-2009, 01:33 PM   #4
Rewards Points: 78
I would replace it, not try to fix it. The newer ones pull much more air and are much more quite.
Ps....get the type with two squirrel cage fans. One motor with a shaft sticking out each end. (dual shaft)
Old 03-24-2009, 11:08 PM   #5
Blo_Fan kitchen exhaust
Been having trouble with the fan slowing down or not rotating at all. Removed motor with bracket from vent opening. Specs include: Western Electric, 3/54 ( Mfg. date?) 110v, 52 watts, .65 amps, ser. no. W6131G12, Mod. 582, 1400 rpm. Lubrication seemed to be the prob. as rotating fan manually required more effort than normal. Lube tubles are at either end of motor housing. Motor operates vertically so lube tubes are horz. starving bearings of oil when operating. Put motor ,attached to bracket in a vise, with holes vertical. sprayed WD-40 to fill tubes, and ran for about i/2 hr. Motor warmed up nicely. and after cooling down turned easier. Reinstalled. Has been running ok. since,( a week). If I have more trouble however I will look for new replacement.
Pryco merged with Emerson a while back, and these exhaust fans apparently went out of production about 10 yrs. ago.
dedbird1 is offline   Reply With Quote
Old 05-31-2013, 09:05 PM   #6
Blo Fan Model 210
I am removing a perfectly good Blo Fan model 210 motor and fan.
these are really solidly built.
Mark
mjt5263 is offline   Reply With Quote
Old 11-15-2014, 01:39 PM   #7
Rewards Points: 2
Anyone have or know where I can get a 9 speed control switch for a Blo Fan 210?
murdawg is offline   Reply With Quote
Insulation under kitchen addition rubicon789 Carpentry 11 01-26-2007 04:24 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 08:17 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 08:13 PM
