Kitchen Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 02:50 AM   #1
Kitchen exhaust fan
Hi, i just asked the question im not an electrician. I just needed help as me and my boss were having a bet and i said that the fan that he put on was ****ed and i was just on here to ask the question, not to be made fun off and i think that u can all go and get ****ed!!!!!
SteveJK is offline   Reply With Quote
Old 11-10-2010, 02:56 AM   #2
help
i have a quston, if u change a single fan on a cormical kitchen exhaust, and u dont get the active and the active together u change to the nuteral will it corse the circet bbeaker to turn off?
Old 11-10-2010, 05:40 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Wow, this is about the most confusing post I have read all day.
Please try again, and this time write in sentences, use a spell checker, use punctuation, and don't write like you are texting. It's "you", NOT "u".
Also, if you are working on the electric on a commercial kitchen you should know what you are doing BEFORE you even walk in the place.
Old 11-10-2010, 05:56 AM   #4
dSilanskas's Avatar
What?!
dSilanskas is offline   Reply With Quote
Old 11-10-2010, 07:11 AM   #5
Licensed electrician
Rewards Points: 1,634
hi i need to know for a kitchen exhaust fan that ius single phase if u change it from the active and nutral will it cut out the circuit breaker?
Please avoid the threadjacks. You have already posted this question elsewhere on the same board.
Sorry to say it but I don't think you have the knowledge to tackle installing the fan with the apparent lack of knowledge and correct terminolgy.
Old 11-10-2010, 07:58 AM   #6
Just call me Andrew
Rewards Points: 1,020
I think this guy knows a lot about circuit beakers!
Andrew
secutanudu is offline   Reply With Quote
Old 11-10-2010, 08:01 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Where ya from ?? due the way the words wrote out and are you in UK or Aussie area ?? that the words that kinda give away.
If you are not really famiur with electrical system I will suggest that you stop right there and get a electrician to come out and deal with it there is too many thing can go wrong if not carefull.
Merci.
Marc
Old Kitchen Brick Exhaust MichaelWayne_71 HVAC 5 12-03-2011 09:22 AM
kitchen range exhaust design ericadami HVAC 2 10-18-2010 12:40 PM
Bathroom exhaust vent in kitchen? dc4nomore HVAC 11 05-27-2009 12:06 AM
Kitchen Exhaust Fan in 12" wall? fw2007 Carpentry 3 03-11-2008 04:12 PM
Recirculating Exhaust Fan in Gas Kitchen - Good/Bad? Crashless Remodeling 5 03-08-2008 09:18 AM
