Old 11-23-2010, 08:57 AM   #1
I ask the impossible!
Kitchen electrical permit
I know this is going to be a question an inspector needs to answer, but I wanted to ask what other peoples experiences are or what I should expect...
If I pull an electrical permit for bringing the kitchen up to code, I suspect I'll have a rough and final inspection, or will it just be final since it's in a room that's already finished?
What raises this question is my thinking about supplying electric to the kitchen in the meantime... I'd rather minimize how much time I'm operating off extension cords. Is it better to run off extension cords until final, or just start using new wiring before final - it would affect whether I approach it as doing the panel first then a circuit at a time or if I can't use anything until done I'd divide it up by expense, probably saving the sub-panel for last.
WillK is offline   Reply With Quote
Old 11-23-2010, 11:52 AM   #2
J. V.'s Avatar
Originally Posted by WillK View Post
I know this is going to be a question an inspector needs to answer.
Correct. Call them and ask them what the procedure is to get a permit and inspection.
Old 11-23-2010, 12:05 PM   #3
I'm getting slightly cynical with these guys because the procedure involves me leaving work an hour early to try to get there by 5 because the permit says they're open until 5, then I put my last quarter in the parking meter only to find out they actually close at 4:30, then come back the next day, get the permit then find a $10 parking ticket because I was out of quarters and the meter vulture swoops in the very second they see you go out of sight on their security camera. (This describes my experience thus far from the second round of permits on this house)
Mostly it's a question of whether this is going to require a rough inspection or not. I have a message in, and the electrical inspector is in afternoons.
Old 11-23-2010, 01:22 PM   #4
If you are opening up the walls and putting in all new wiring then most likely you will have a rough inspection and a final.
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
DIY Electrical. Permit, Inspection, Liability Concerns Stemboat Electrical 13 08-01-2010 05:21 PM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
Choosing colors for painting living room, kitchen Bugpals Painting 2 05-15-2009 10:19 AM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 10:45 AM
