Kitchen Electrical - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 06-07-2012, 05:16 PM   #1
kitchen electrical
what kitchen appliances need dedicated electrical breakers
kahuna 22 is offline
Old 06-07-2012, 05:19 PM   #2
how about the refrigerator
Old 06-07-2012, 05:22 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Well, to keep this clean and simple, in a nutshell, if the manufacture of the appliance requires a dedicated circuit, then you don't have an option.... other wise I use the loads on the name plates and whether they are fastened in place or not to determine what gets what for circuits.
stickboy1375 is offline
Old 06-07-2012, 06:43 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,102
Some large draw loads could require dedicated circuits.
Some others are required by code.
Which would vary depending on locality.
To which one are you referring ?
dmxtothemax is offline
Old 06-07-2012, 06:45 PM   #5
Rewards Points: 6,652
Making it simple: Electric Stove or electric oven needs its own, Dishwasher can share the same breaker for the garbage disposal if there is one, or also with a trash compactor, as long as all three together do not exceed the total amount of amps for the circuit. Microwave needs its own, whether it is a over the range, or counter top that sits on a shelf, or somewhere on the counter. Fridge can share either off of the Branch circuit that does the counters, gas stove can also share off of the counter branch circuit. Lighting needs to be on its own circuit, but can share off of other rooms.
The branch circuits for the counters can also do the baseboard outlets, dining area, pantry, can not feed any other rooms in the house.
gregzoll is offline
Old 06-07-2012, 07:14 PM   #6
E2 Electrician
Its really a vague question... without looking at the appliances, your guess is as good as ours...
Old 06-07-2012, 07:26 PM   #7
Not vague. See post above yours. Simple question, especially for Kitchens, is about the easiest to answer, since it is already spelled out in the NEC regarding SWBC & Kitchens, along with beaten to the death on this forum, that the horse has nothing else to give.
gregzoll is offline
Old 06-07-2012, 07:34 PM   #8
E2 Electrician
I don't see how you can determine a branch circuit with out a nameplate, but guess thats how you roll, just like your imaginary dedicated circuit for a microwave, how bout a code reference on that one....
Old 06-07-2012, 08:00 PM   #9
joed's Avatar
Rewards Points: 11,998
Where do you live? I Canada the fridge is required to be dedicated.
joed is offline
Old 06-07-2012, 08:48 PM   #10
It is not imaginary for a dedicated circuit for the mic. Modern microwaves NEED their own circuit, because of the amount of current draw they alone make. Even without a nameplate, again it is spelled out in the NEC as to what guidelines for requiring WHAT needs a dedicated or does not need a dedicated circuit, and to what you can and can not do with the Small Appliance branch circuit for the Kitchen/dining area/pantry. Nothing imaginary about it, but in your world.
Btw, a 1,000 watt mic draws 8.3 amps when it is on. But hey, if you want to share with that load while it is on, have fun running back and forth resetting the breaker. Now of course, if you are like me, you take the second SWBC and use it for the mic, because in my small kitchen, I only need one circuit for both counters, and can always go and make a small change downstairs ahead of time, if I need to break it out to a third circuit.
gregzoll is offline
Old 06-08-2012, 07:10 AM   #11
E2 Electrician
lol... so in your words, A microwave doesn't require a dedicated circuit, YOU just choose to supply one... thats fine and dandy.....
And I know what the NEC requires... and it's not a dedicated circuit. Hence the title of the OP's topic.
Old 06-08-2012, 08:26 AM   #12
lol... so in your words, I microwave doesn't require a dedicated circuit, YOU just choose to supply one... thats fine and dandy.....
Again, cite the section that states your opinion. Sorry, but as already mentioned a 1,000 watt microwave uses 8.3 amps. Anyone that is smart or has half a brain, will give it its own dedicated outlet.
gregzoll is offline
Old 06-08-2012, 08:50 AM   #13
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Show us the CODE that it does.
k_buz is offline
The Following 3 Users Say Thank You to k_buz For This Useful Post:
electures (06-10-2012), Jim Port (06-08-2012), stickboy1375 (06-08-2012)
Old 06-08-2012, 09:08 AM   #14
Licensed electrician
Rewards Points: 1,264
I am glad the NEC does not call for a dedicated circuit for a countertop microwave. Can you see trying to decide where it would go on the counter when doing the install? Wait, the HO doesn't want it there so you need to rewire?
Side note: my 1450 watt MW drawing 13.5A is incorrectly installed on a 15 amp lighting circuit and rarely trips the breaker. I am not endorsing this practice and plan to change it, but it is a low priority at the end of the day.
Jim Port is online now
Old 06-08-2012, 10:08 AM   #15
Rewards Points: 776
Wow for someone who just joined the forum that's an aggressive tone. Take a pill and dial it back some. Everyone is just trying to help out here. Last time I checked there were no salaries being paid to anyone.
curiousB is offline
The Following User Says Thank You to curiousB For This Useful Post:
J. V. (06-12-2012)
Closed Thread
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 10:45 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 10:19 AM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 11:23 AM
got rid of kitchen island, how to get rid of the electrical wire from floor ckcrew Electrical 15 12-14-2006 10:45 AM
