Kitchen Countertop Recept. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-18-2014, 08:37 AM   #1
JD45Grn's Avatar
Kitchen countertop recept.
Hi all, new here! Not to electrical work however. My younger brother and I are in the midst of remodeling and converting the 2nd floor of my house into a small apartment for him (Permit pulled for the job). We're in the process of roughing in the electrical (I live in NH if that helps). Would someone kindly fill me in on the countertop receptacles in the small kitchen we're building? It's going to have a mini fridge, apartment size gas oven/stove and the usual microwave, toaster, toaster oven, sink, etc... My question is, how many GFCI protected receptacles can I have on a single circuit? We have installed 4 outlet boxes for the receptacles. Can all 4 receptacles be on the same circuit? Also, does the mini-fridge need it's own circuit? Perhaps I'm thinking of something else but I thought I overheard someone who claimed to be an electrician that the fridge had to be on it's own dedicated circuit. All comments and suggestions are welcome. Thanks in advance for the help.
JD45Grn is offline   Reply With Quote
Old 06-18-2014, 09:04 AM   #2
Licensed electrician
Rewards Points: 1,598
There is no limit on GFI protected receptacles under the NEC.
You need at least 2 20 amp small appliance circuits serving the counters.
No space on the counter more than 2 foot from a receptacle.
CarpenterSFO (06-18-2014)
Old 06-18-2014, 09:15 AM   #3
Pro
Rewards Points: 91
2011 NEC 210.52.B.1 allows the refrigerator to be supplied by one of the the 2, 20-amp kitchen receptacle circuits, but it also permits it to be supplied by its own 15-amp or greater circuit.
2013 California electrical code allows the same. Check current NH electrical code at that number to see what your local situation is, or go check at your local AHJ.
Robert Cram
Robert Cram Construction
CarpenterSFO is offline   Reply With Quote
Old 06-18-2014, 10:25 AM   #4
JD45Grn's Avatar
Mr. Jim Port, Just to be sure I understand this clearly; Seeing I have 4 receptacles serving the counter space, then I need to break them up into 2 20 amp circuits, each circuit GFCI protected, correct? Or am I reading too much into this? I tend to over analyze things so please excuse the questions. Roger
Old 06-18-2014, 10:55 AM   #5
Rewards Points: 13,690
That is correct.
Old 06-18-2014, 11:05 AM   #6
JD45Grn's Avatar
Thanks to all 3 of you kind folks by helping me out and clarifying that for me. I appreciate it. Roger
Omnigrip adhesive for tiling kitchen countertop? tforse Kitchen & Bath Remodeling 3 04-29-2011 06:33 PM
Kitchen countertop outlets dairyman Electrical 5 04-11-2011 08:13 AM
kitchen countertop gap @ wall mxtr Kitchen & Bath Remodeling 10 05-27-2010 08:33 PM
Replacing kitchen countertop tile budget consciou Remodeling 5 03-17-2009 09:24 AM
Has anyone installed a Swanstone kitchen countertop? Oak Creek Ter Kitchen & Bath Remodeling 2 03-04-2009 01:00 PM
