Kitchen Countertop Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 07:38 PM   #1
Kitchen countertop outlets
Hi, I am a homeowner in the middle of an extensive gut and remodel of a old farm house. I have updated all the wiring and am now hooking up outlets, lights ect. To make a long story short I need to install TR outlets in the 20amp countertop circuts but where the heck do I get them? No one seems to carry them. I can get 20amp TR GFCI's but not 20a duplex TR outlets. Any advice? Is it to code to use 15a TR duplex outlets? Help!
dairyman is offline   Reply With Quote
Old 04-10-2011, 07:43 PM   #2
I=E/R
a7ecorsair's Avatar
You do not need 20 amp receptacles. Can you find 15 amp TR's?
a7ecorsair is offline   Reply With Quote
Old 04-10-2011, 07:47 PM   #3
Master Electrician
Rewards Points: 3,960
It makes a difference where you are and what code cycle you are under. For instance, Indiana has exempted arc faults and tamper resistant receptacles.
brric is online now   Reply With Quote
Old 04-10-2011, 08:00 PM   #4
Licensed electrician
Rewards Points: 1,874
If there are more than one place to plug into on the 20 amp circuit you can use the 15 amp slotted duplex receptacle.
Old 04-11-2011, 08:09 AM   #5
thanks
I am in Minnesota and I can get the 15a TR outlets (code states that I need them in the entire house) If I am good to put them in after the 20a GFCI then I have no more problems. Thanks
Old 04-11-2011, 08:13 AM   #6
You can use 15 amp duplexes downstream of the 20 amp GFI.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
do I need GFI for all kitchen counter outlets DanDaMan Electrical 2 03-06-2011 06:33 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
kitchen countertop options momof2labs Kitchen & Bath Remodeling 13 02-08-2010 03:57 PM
why would kitchen outlets stay on if 1 leg out pag Electrical 4 05-05-2009 06:45 PM
