Old 05-10-2012, 08:20 PM   #1
Kitchen counter and island outlets
I will be extending the kitchen counter about 6 ft from the last of 4 outlets on a 20A circuit. I assume I must add another GFCI outlet. Can I have 5 outlets on this 20A circuit? I also need an outlet on the island. Can it be on the same circuit?
elmaur is offline   Reply With Quote
Old 05-10-2012, 08:27 PM   #2
Licensed electrician
The NEC only requires a minimum of 2 20 amp circuits to serve the countertops.
If the extension will already be downstream of a GFI there is no need for an additional one.
Yes, the island will require at least one GFI protected 120 volt receptacle.
Old 05-10-2012, 08:43 PM   #3
??? So are you saying I need to pull another 12/2 because I am adding the fifth oulet in which case I would put 2 outlets on one circuit and 3 on the other? Does the island outlet have to be on its own circuit?
Edit: I am not sure if you answered that the island can be on one of the 2 20A counter circuits?
Old 05-10-2012, 08:48 PM   #4
Pure Genius
Jim said 2 circuits. Just extend your circuit for your ctop and island and call it a day
Dierte is offline   Reply With Quote
Old 05-10-2012, 11:34 PM   #5
hmm...that sure clears things up. There is just one 20A circuit now. If I extend it I still have one circuit. I don't think that is what you meant. I will run another 12/2 to add the 2nd circuit. I'll have 6 outlets total so I'll do 3 outlets on each and then call it a day... unless somebody objects.
Old 05-11-2012, 12:49 AM   #6
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If it's easy to do now then it may be a good idea.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-11-2012, 06:21 AM   #7
Pure Genius
Missed the part where you said only one circuit.
Old 05-11-2012, 07:46 AM   #8
kevinp22's Avatar
code requires 2 20a rec to serve kitchen/dining/pantry loads and both must be present at the kitchen counters (i dont have the code reference handy)
i would definitely pull a second circuit. and while you are at it, consider dedicated circuits for the microwave (if its an above the range model) and refrigerator
kevinp22 is offline   Reply With Quote
Old 05-11-2012, 01:48 PM   #9
I do appreciate everyones help here but as I read, some of the advice is unclear. Someone I was casually talking to about my renovation said something about the island outlet had to be on its own circuit. What you are saying kevinp22 seems to go along with that but maybe not. Do I need 2 20A circuits at the counters plus one for the island or can the 2 counter circuits include the island?
I have dedicated circuits for microwave and refrigerator. No confusion about that!
Old 05-11-2012, 01:58 PM   #10
Licensed Pro
The island receptacle may be shared with other countertop circuits, but must be GFCI protected. You need at least two 20A circuits that serve the countertops.
Old 05-11-2012, 02:03 PM   #11
Well that seems to be clear enough, thank you.
Old 05-11-2012, 03:21 PM   #12
kevinp22's Avatar
Well said househelper. My response wasnt as intuitive as yours.
