Kitchen Circuits - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 10:01 AM   #16
DIYer
Rewards Points: 262
Guys, sorry to beat this dead horse but I really appreciate the info.
So, I can't add the pendant lights to my two kitchen SABC. And it sounds like my 20A microwave circuit is considered a SABC since it supplies receptacles in the kitchen. It has a GFI wall receptacle above the counter and then one more that will be inside the upper cabinet for the microwave. I think that leaves me with with just two options...add these pendant lights to my 15A lighting circuit or run a new circuit. Is that correct?
My only other outlets in that area are the dining room receptacles which are all on the SABCs.
mystic_cobra is offline   Reply With Quote
Old 07-31-2011, 10:05 AM   #17
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by mystic_cobra View Post
Ok, so would it be correct to say, "an outlet is a box in a circuit where a receptacle or switch may be installed".
Or nothing installed. Could just be a junction box with a blank cover.
So, what properties define a kitchen SABC. Is it any circuit with receptacles above a kitchen counter? Any circuit with receptacles in a kitchen?
In general, a circuit with receptacles in a kitchen, dining rm, breakfast nook, etc. Not all SABC receptacles are mounted above a kitchen counter. To me, this is almost being thought of backwards.
Kyle
Old 07-31-2011, 10:13 AM   #18
Electrician
SD515's Avatar
Rewards Points: 504
The micro should be on its own dedicated circuit, not tied in with the counter, check the instructions. Correct, the lights would have to come from another circuit or a new circuit.
Kyle
Old 07-31-2011, 11:55 AM   #19
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I am finishing up the wiring in my kitchen remodel and I have a question about this same setup specifically about the last statement regarding adding lights to a small appliance circuit...
I have all of the circuits in place as suggested above. I need to add two pairs of over-bar pendant lights over the bars I'm adding to the kitchen. One pair switched on each of two opposite walls. It seems dumb to add these to the 15A lighting circuit which already has 7 recessed lights, a ceiling fan/light combo, dining room chandelier, plus three outlets in the adjacent family room (end table lamps). I've done the math and even with all the lights on, I'm still okay. The 20A small appliance circuit will power a toaster and a blender a few times per month. Most likely these two appliances will never run at the same time. It just seems silly to have this appliance circuit that is so underutilized.
I have a third 20A circuit (GFCI protected via receptacle) in the kitchen that has two receptacles. Only thing connected will be a 1600W microwave. Can I (should I) put these two sets of switched lights on this circuit instead of the lighting circuit?
No lighting on SABC's. Add it to the lighting branch circuit.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-31-2011, 11:57 AM   #20
electures's Avatar
Old 07-31-2011, 01:20 PM   #21
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
I was under the impression that a switch box is not an outlet, only boxes in which a receptacle is/or could be installed and all lighting fixture boxes. Not sure what the NEC 2011 rule requiring a neutral in all switch boxes does to my impression.
The end run of a 3 way switch even with a 4 wire cable to provide a neutral does not necessarily have a constant hot to make it an outlet.
Coastal South Carolina
Old 07-31-2011, 01:58 PM   #22
Electrician
SD515's Avatar
Rewards Points: 504
Unfortunately the definition is vague. Again, the 2008 definition: Outlet: A point on the wiring system at which current is taken to supply utilization equipment.
Points of thought (in my opinion): A 240V box qualifies as an outlet box, though no neutral exist. A dead-end of a 3-way that has a neutral available qualifies, as current can be taken. No mention in the definition that the power has to be constant. For that matter, a 3-way without a neutral would qualify, as current is taken from one conductor and transferred to another, with the final result supplying utilization equipment, though that equipment is not necessarily attached to that particular device. Again, opinion. Gotta love the vagueness of the code sometimes.
Kyle
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
Yet another Kitchen Sub-panel Post...Sorry tpagel Electrical 4 03-19-2011 09:54 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Kitchen reno, any better suggestions? mgarfield Remodeling 7 01-20-2010 03:37 PM
Kitchen remodel frank551 Electrical 2 11-15-2005 07:13 PM
