Kitchen Ceiling Light Is Buzzing...is This Normal? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 11:41 AM   #1
harleyman's Avatar
kitchen ceiling light is buzzing...is this normal?
I have 6 different lights installed into the ceiling of my kitchen, all connected to the same switch. However, one of the lights always starts to make a buzzing noise a few mins after I turn the lights on. It is a buzz that will go for anywhere from a few seconds to almost a minute. Then there will be a period of no noise, and then it starts again. And the cycle continues until I turn the lights off. Like I said, I have 6 lights total and only one of them makes this noise.
Has anyone every heard of something like this? And if so do you have any suggestions?
Thanks!
harleyman is offline   Reply With Quote
Old 07-02-2010, 12:43 PM   #2
Just call me Andrew
Rewards Points: 1,020
Are they fluorescent lights? Could be a bad ballast.
Andrew
secutanudu is offline   Reply With Quote
Old 07-03-2010, 03:01 AM   #3
Mad Scientist
Yeah, what kind of lights are they? If they're not fluorescent, then it sounds like you've got a loose connection arcing a bit, which could lead to a fire. You would want to take that light down and check all the connections.
McSteve is offline   Reply With Quote
Old 07-03-2010, 07:09 AM   #4
Rewards Points: 1,418
Try a different light bulb.
If the light dims as it buzzes, you almost certainly have a loose connection that is arcing
To improve the contact of a screw in bulb, loosen it a quarter turn and then retighten. Do not make it too tight or it may be hard to take out when the time comes.
Old 08-04-2010, 10:27 AM   #5
harleyman's Avatar
Thanks for the comments. It's a brand new set up as well as new light bulb. A friend said it was probably the spring in the light bulb itself so I'll try to fix that today and just get a new bulb from the store...hopefully it works, if not I'll be back on here again so you guys can help me out! lol
Old 08-05-2010, 09:28 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Swap that lamp with another one in the room and see if the buzzing moves, stops or stays in the same place.
Old 08-06-2010, 01:32 AM   #7
Rewards Points: 410
I've had some cheapo incandescent bulbs make a noise before.
I got rid of them problem solved , crappy light anyways.
High Gear is offline   Reply With Quote
Old 08-18-2010, 03:39 PM   #8
harleyman's Avatar
Switched out the bulbs out and it seems to have fixed itself...maybe it was the connection, maybe the bulbs. Just glad there is no more noise!
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 09:14 AM
replace ceiling fan with ceiling light pglc General DIY Discussions 11 06-08-2009 07:12 PM
