Kitchen Cabinet LED Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 01:02 PM   #1
Kitchen Cabinet LED lighting
Want to install under cabinet lighting in existing kitchen.
Have existing split receptacles (Pre GFCI age) all used.
Want to install new switch in new switch box and use LED ribbon lighting under cabinets. Total power draw under 40w
What is correct wiring procedure from LED driver to switch?
What wire and what protection for wire goes from driver (mounted under cabinet) through drywall board to switch box in wall cavity?
Steve Brockhouse
Stevebr is offline   Reply With Quote
Old 06-29-2012, 01:27 PM   #2
Licensed electrician
Rewards Points: 1,632
It sounds like you may be in Canada. I do not know if the CEC would allow lighting loads on the small appliance countertop circuits.
Old 06-29-2012, 02:21 PM   #3
Yes. In Ontario.
I have access to separate circuit. (Not one of split duplexes)
I can bring the romex into the new switchbox.
I need to know if the input cable that comes with the driver can be taken through the drywall into one of the clamped ports of the switchbox. If I do, does the exposed part of this cable need extra protection?
The light manufacturers suggest their products can be direct wired, but I'm not sure this meets code.
Wiring for under cabinet lighting fredm54 Electrical 15 06-16-2012 12:23 PM
Hard wiring under cabinet lighting demandrew Electrical 14 02-24-2012 09:31 AM
Under cabinet lighting iceman536 Electrical 8 05-02-2011 09:18 AM
Kitchen cabinet conundrum allbymyself Kitchen & Bath Remodeling 18 01-24-2011 11:11 PM
Another cabinet lighting question bcbud3 Electrical 0 10-25-2010 11:35 PM
