Kitchen 20a Small Appliance Circuts No Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 02:28 PM   #1
Rewards Points: 83
when we redid our kitchen, we put in...
2 20a circuits for the counter tops
1 20a for dishwasher, disposal
1 20a for microwave/stove ignitors
1 20a for fridge
1 20a for lighting
Its my understanding that you are to have no lighting on the counter top circuits. Now a year later i am finally getting around to putting in the under/in cabinet lighting, it's low voltage LED's and i am wondering if its against code to wire them to the 2 20a small appliance circuits? I put specifically placed outlets inside and right below my cabinets but now i realize these outlets are running off of the appliance circuits.
linuxrunner is offline   Reply With Quote
Old 08-01-2011, 02:36 PM   #2
Master Electrician
Rewards Points: 3,870
Code violation.
brric is online now   Reply With Quote
Old 08-01-2011, 02:42 PM   #3
Rewards Points: 83
Nuts!
Guess I'll need to punch a few holes in my new walls to run power down from the lighting circuit. Next owner of this house may be really confused by our choice of outlets inside and just under cabinets
Old 08-01-2011, 04:43 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I believe if you use plug in (as opposed to hard wired) under cabinet lights it will not be a code violation.
Coastal South Carolina
Old 08-01-2011, 07:53 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
True.
Kyle
Old 08-02-2011, 02:23 PM   #6
Rewards Points: 83
Anything stopping me from wiring a plug on the end of a hard wired system and plugging it in?
Old 08-02-2011, 03:04 PM   #7
Rewards Points: 6,652
Yes, the U.L, and the NEC/CEC.
Old 08-02-2011, 03:46 PM   #8
A "Handy Husband"
rjniles's Avatar
That would violate the UL listing for the light.
You could install a combination device on the SABC (1/2 receptacle, 1/2 switch) and plug a plug in under cabinet light.
Old 08-02-2011, 06:20 PM   #9
Rewards Points: 83
Sounds like that's by best bet, at least it's better then running new wires.
Old 08-02-2011, 08:51 PM   #10
Electrical Contractor
kbsparky's Avatar
We used undercabinet lights with a cordset on it ... and installed a wiremold box under the cabinet with a receptacle in it. You can install that outlet on the SABC, and plug it in, and be perfectly Code legal.
But direct wire the same fixture into the same circuit, and you have a violation.
Both installations are just as safe, in fact, the direct wired version is probably safer. But this is one instance where the Code is not interested in safety, but has crossed the line into design aspects --> something that they claim they don't engage in if you read the preface.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
SD515 (08-03-2011)
Kitchen Lighting Plan - Plz Comment vsheetz Electrical 10 01-29-2009 11:14 AM
lighting layout for the kitchen Did it myself Interior Decorating 4 01-24-2009 09:13 PM
Do I need a new box? pcampbell Electrical 20 01-07-2009 06:16 PM
kitchen questions mivon Electrical 3 04-15-2008 07:50 AM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 10:38 AM
