Kinked Romex - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 04:34 PM   #1
kinked romex
When pulling romex, and kinking it, how can you tell if the wire is actually damaged or if it's still fine? I understand that the best answer is probably "replace it" but is there a way to tell if it's damaged, either by look or touch? Thanks.
Tonglebeak is offline   Reply With Quote
Old 09-24-2013, 04:44 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
How does one go about kinking it?
Old 09-24-2013, 05:57 PM   #3
Rewards Points: 6,652
Usually happens when one person is pulling, and no one is standing at the roll laying on the floor, watching it get pulled up the wall, etc.. Any wire will kink, if you do not lay it out so that it pulls flat.
Old 09-24-2013, 06:04 PM   #4
biggles's Avatar
no problem except for the looks of it grab it and un-bend it flat,you could bend a piece of romex for half hour and the copper won't snap
Old 09-24-2013, 07:13 PM   #5
E2 Electrician
It was a rhetorical question.....
Old 09-24-2013, 07:51 PM   #6
And you were not being Rhetorical in your reply? As for the question, so they made a statement that they were just probably speaking out loud to begin with.
Really all you have to do in these types of questions, is just post an answer to the question, or just read the post, let it bury itself into the nether regions of the forum database.
Old 09-24-2013, 10:34 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,362
Not always !
Sometimes they can break internally and show no indications of damage,
But this is rare !
Best way to tell is a continuity check with a meter !
You can also visually inspect it for obvious kinks.
But it usually doesn't break easily.
dmxtothemax is offline   Reply With Quote
Romex on basement wall to panel iceclimber2001 Electrical 3 08-13-2012 07:40 AM
Identify age of old Romex - also funny ground Leah Frances Electrical 9 02-06-2012 12:07 AM
How to build a romex spinner jimmy21 Electrical 17 02-06-2012 12:01 AM
Fishing Romex through walls Tetranitrate Electrical 6 07-09-2011 06:12 AM
romex clamped against bx knockout in old box kbm774 Electrical 11 08-16-2010 01:53 PM
