Kiln Wiring Three Phase - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 07:52 PM   #16
Found one for 500 that is close. 600v for the hv and lv is 208/120. Also says 75kva. How close is this to 100% power
Torchwork is offline   Reply With Quote
Old 05-31-2012, 09:48 PM   #17
Semi-Pro Electro-Geek
Rewards Points: 2,922
Nope, won't work. You need a 240V delta primary, 600V delta or 347/600V Y secondary. If you can find a used transformer for cheap that will work, and if your existing panel can handle the load, then you could do it. However, I would not expect to find the right transformer at a reasonable price.
It might be possible to re-wire the elements in the kiln to work with your supply. It depends on how the individual elements are configured. Many high-power heating devices use a bunch of smaller elements, and are reconfigurable for different voltages and phase configurations by rewiring the elements. However, I don't think this project is within your skill range. In fact, this entire installation is probably not something you should be doing. This is clearly commercial work, which generally must be performed by a licensed electrician. Also, higher line voltages like 277 and 347V are very dangerous, and transformers require a professional level of knowledge to install safely.
mpoulton is offline   Reply With Quote
Old 05-31-2012, 10:04 PM   #18
Sparky
Rewards Points: 510
I'm going to have to recommend you find a local licensed electrician to assist you with this. 600v is very dangerous, if anything is done wrong.
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
Speedy Petey (06-01-2012)
Old 05-31-2012, 11:01 PM   #19
I appreciate the help very much as well as the recommendations per safety reasons. I really just needed the info to see what my options are with this kiln. It doesn't need to run at 100% power but I would like it to heat faster than it does right now. Thanks again.
Old 05-31-2012, 11:18 PM   #20
" Euro " electrician
frenchelectrican's Avatar
There is couple thing it kinda show semi red flag half way up so let me ask you a basic question here.
A) What size service ( main breaker ) you have in your place ?
B) What voltage and phase you have in there ?( not for the kiln but for whole system )
If not sure you can post a photo otherwise a electrician can asssit you on this one.
However if you have single phase service you will denfitally need more than just a 200 amp service due your kiln size is pretty huge but if three phase it depending on main breaker rating / voltage you have there as I posted the question above.
Merci,
Marc
Note : normally three phase system is generally best done by electrician due can get tricky with connection if not heeded on that.
Old 06-05-2012, 10:05 AM   #21
Would a 240v pri 575y/332v be close enough to full juice?
Old 06-05-2012, 10:14 AM   #22
The subpanel I have is 240 3phase more than 200 amps
Old 06-05-2012, 01:17 PM   #23
Idiot Emeritus
Rewards Points: 1,492
As long as it's rated at more than 47 KVA it'll work for the kiln. The difference between 575 and 600 is too small to matter.
Even though it's technically not completely correct, a 45 KVA would work if it was fan cooled and installed in a fairly cool environment.
Dry-type transformers are almost always rated for installation in still air at 104F.
Most dry-type substation transformers I work with have two KVA ratings, one for AA (atmospheric aspiration) and a higher one for FA (forced aspiration).
Just last week, I added a new feeder to a switchgear that was fed from a dry-type transformer that was rated 1500 KVA AA and 2000 KVA FA.
Rob
micromind is offline   Reply With Quote
Old 06-05-2012, 01:24 PM   #24
Idiot Emeritus
47 KVA @ 240 3 = 113 amps.
There'll be some loss in the transformer, but not very much.
If you're driving a 600 volt kiln with 575, the actual current will be a bit less.
Using the transformer described above, the 240 volt current will be somewhere around 100 - 115 amps, depending mostly on exactly what voltage the 240 runs at.
Rob
Old 06-05-2012, 02:40 PM   #25
You are very likely to overload your panel or the service. The kiln will draw well over 100A equally on all three phases. If you have any other heavy loads, you'll exceed 200A pretty easily. Perhaps more importantly, your service appears to be 120/240V high leg delta. It may be supplied by only two transformers, or possibly three, Either way, the power company's transformers are not sized for heavy 3-phase loads. They are sized for heavy 120/240V loads on one transformer, and a small amount of additional 3-phase load. This is probably going to roast their transformer bank.
Old 06-05-2012, 03:49 PM   #26
I have get access to the main panel later, but this is in an industrial building with many bays. Luckily I'm the only one that uses electricity. Shouldn't the transformer only draw 180 amps? Another option I am considering is only going up to 480v which would allow the kiln to run at 64%. Any thoughts?
Old 06-05-2012, 06:58 PM   #27
180A? It should be 113A, plus whatever the losses in the transformer are. Although I think the nameplate says the load on each phase is not completely balanced, so one phase might be a bit more. If there are any other substantial loads on the panel, you're likely to overload it. More importantly, like I said, you're likely going to overload the high leg of your service since it was never intended to supply such a large 3-phase load.
Edit: You should have two phases running 125A and one phase at 108A, plus transformer losses.
Old 06-05-2012, 08:46 PM   #28
Idiot Emeritus
Whether 480 will work or not depends on whether the kiln will get hot enough with the reduced amount of heat.
If you do go 480, a 45 KVA transformer will be fine.
Just for info, it doesn't matter if the transformer is 240 primary or 240 secondary, any transformer this size can be fed either way.
The 480 or 600 volt side can be either wye or delta. There's a slight difference in how it's connected, but either one will work.
Rob
The Following User Says Thank You to micromind For This Useful Post:
Torchwork (06-05-2012)
Old 06-05-2012, 08:50 PM   #29
Idiot Emeritus
I don't understand how a balanced 3 load can result in unbalanced current in the transformer feed.
I'm pretty sure (as in pretty much positive) that a balanced 3 load will result in balanced current in all parts of the circuit, assuming balanced voltages and phase angles.
I'd be really interested in knowing where these figures came from.
Rob
Old 06-05-2012, 10:20 PM   #30
It's not a balanced load. Take a look at the nameplate photo he posted above. It says 50/43/50A.
KILN: 75 Amp, 1 phase - Residential Basement Install luxou812 Electrical 8 02-03-2012 11:39 AM
Three phase transformer question rongaudier Electrical 8 03-08-2011 07:19 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
3 phase electricity J187 Electrical 11 10-26-2006 01:40 PM
