Kiln Controller Design - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2011, 04:28 PM   #1
Mat
Hi All,
I'm currently working on designs for an AC controller which will switch about 220-240V 35-40A on/off to control temperature in the kiln.
the high voltage part will just be the kiln power cord plugged into a socket on the controller wich will have one of the fused hot lines connect to the switching relay. the output of the 3 wires will exit the box, and return to the same type of cable for plugging into the 220-240V wall outlet (still waiting on the spec) (the controller will eseentially be a splice into the power cord of the kiln)
the relay will be controlled by a microcontroller with a thermocouple input.
the concerns i have so far;
using appropriate AWG wire (with safety margin 125% capacity) with appropriate color coding
fusing the input before the relay
making sure the copper wire is mated to the relay terminals in a way that will not facilitate corosion
weatherproofing the containment box (might be located outside under a carport
heatsink on the relay
case will be plastic and a 12V DC wall/wart will power the microcontroller plugged into a standard 110 wall outlet. the DC voltage will control the relay which is optoisolated within the relay from the AC power.
Is there anything i might be overlooking from a safety standpoint? anything that i might be concerned about for being compliant with the NEC?
Mat is offline   Reply With Quote
Film / Photo Studio Interior Design BryanRoberts Interior Decorating 5 11-30-2011 06:31 PM
How To Check A Steel Carport Design abrogard Building & Construction 8 10-05-2010 04:59 AM
Wiring Solid State Fan Controller mntnvew Electrical 7 07-16-2010 05:31 PM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 12:02 PM
