Keyless Fixtures...What To Do With Ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2010, 01:35 PM   #1
Keyless Fixtures...What to do with ground wire?
When wiring a parallel circuit with keyless fixtures, what do I do w/ ground wire at the end of the circuit? There is no grounding posts on the plastic keyless fixtures and being at the end of the circuit, there is no other runs to join the grounds to. Any help would be appreciated!
Driven2race is offline   Reply With Quote
Old 01-16-2010, 02:07 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Just fold it back in the box. DO NOT cut it off short.
Old 01-16-2010, 02:14 PM   #3
So no wire nut or electrical tape needed on the exposed ground? Do I fold it back so it touches itself, or just fold it back to keep it out of the way? Should I be worried about it possibly touching the other exposed posts when fixture is pushed up into housing?
Old 01-16-2010, 02:16 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Since it's a solid wire, if you fold it into the back of the box, it'll stay there.
Plus, the other wires will help hold it in.
No need to tape it or wirenut it.
Rob
micromind is offline   Reply With Quote
Old 01-16-2010, 02:17 PM   #5
Nope.
It's bare. It doesn't matter if it touches itself. Just make sure it is tucked back enough to not touch the fixture.
Absolutely. See previous question.
Old 01-16-2010, 02:22 PM   #6
Awesome, thanks guys!
Old 01-16-2010, 06:42 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
IF the box is not on the end of a run (so there will be 2 or more cables entering the box) be sure to wire nut all the grounds together.
I presume you had done this due to the specificity of your question but just wanted to be sure.
Um, one question though: these are plastic boxes, right?
If they are metal boxes, the ground wire also has to be attached to each box with a ground screw or one of those funky little clips that I hate that clip onto the side of the box.
Old 01-17-2010, 09:38 AM   #8
Registered User
Termite's Avatar
Just to be sure this gets seen! Very important!!!
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
Ground wire behind baseboard disx2000 Electrical 8 05-30-2009 11:51 AM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
connecting ground wire to ground screw amakarevic Electrical 10 12-24-2008 04:28 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
