Key Card Switch For Hotel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2014, 05:02 AM   #16
Rewards Points: 282
I stayed in a hotel in NYC that had this.
dgfit is offline   Reply With Quote
Old 01-04-2014, 06:57 AM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I don't get the usefulness of it. I get the turning on part, but how would it know how to turn off? When a guest open/shuts the door? Not a good idea. Let's say the guest turns the lights on with the card, then decides to run to get some ice. Props the door with the lock, comes back, closes the door, the lights now go off.
If you have to insert your key card into a different reader inside the room to turn the lights off, it's no different than a switch. You are relying on the guest to turn them off. Some will turn off the lights, some won't, either way, the maid will be in shortly.
The Following User Says Thank You to k_buz For This Useful Post:
gregzoll (01-05-2014)
Old 01-04-2014, 07:30 AM   #18
An old Tradesmen
Rewards Points: 7,816
The guest puts the key card in the reader, and leaves it in the reader. As long as card is in reader, the electric is on. Since its the same card as the entry card. When the guest leas the room to go out to meeting or amusements, the device turns the electric off after the card is removed for 15 seconds.
In areas whee electric is over 20 a KWH, this can save a large amount of money over a years time.
Imagine 300 rooms using just 70 less KWs an hour for 6 hours a day. It would be an operating cost eduction of over $9,000.00 a year at 20 cents a KWH.
Old 01-04-2014, 07:40 AM   #19
k_buz's Avatar
At your numbers, that's $30 bucks a room. Imagine the cost to retrofit a hotel. Between labor and materials, I think you are looking at about 500/room minimum. A new install would be cheaper, but $200/rm would be a low average in my mind. So, that would mean that these would have to save $30/year for 7-16 yrs to pay for itself.
Old 01-04-2014, 07:53 AM   #20
An old Tradesmen
I would think something like this would be done during a planned renovation. Where the walls are going to be opened up already. Not just on a save money whim.
Old 01-04-2014, 08:11 AM   #21
Electrical Contractor
kbsparky's Avatar
Originally Posted by dmxtothemax View Post
... electricity is expensive here
currently 27c/ KWH ....
GASP! That is expensive!
More than double what we pay here, but there are areas in the US that have much higher rates these days, due to recent mandates implemented by the EPA with the loss of coal-fired power plants ...
-KB
Old 01-04-2014, 08:18 AM   #22
An old Tradesmen
In the Cayman's, they pay 37 cents a KWH( thats info is from a friend 2 years ago). Its expensive to run those diesel generators.
Old 01-04-2014, 09:12 AM   #23
Rewards Points: 282
I don't get the usefulness of it. I get the turning on part, but how would it know how to turn off? When a guest open/shuts the door? Not a good idea. Let's say the guest turns the lights on with the card, then decides to run to get some ice. Props the door with the lock, comes back, closes the door, the lights now go off. If you have to insert your key card into a different reader inside the room to turn the lights off, it's no different than a switch. You are relying on the guest to turn them off. Some will turn off the lights, some won't, either way, the maid will be in shortly.
You have to use your room key card to turn on the lights and you have to leave the card in the a lot for the lights to stay on. So you remove your key when you leave or you can't get back into the room when you return.
(Sorry - just saw that someone posted this same thing)
Old 01-04-2014, 09:07 PM   #24
Rewards Points: 336
Well, apparently someone has done some math that shows these systems are worth it, because you will find them in lots of hotels in Europe. Obviously new construction is the simplest way to implement it.
People are mentioning things a system like this can turn off - lights, TVs, etc. It also can turn off air conditioning, which uses lots of electricity.
JKeefe is offline   Reply With Quote
Old 01-04-2014, 11:41 PM   #25
k_buz's Avatar
Or it's another feel good product pushed by the energy conservation crowd. This is the good old USA however, if there is a true need for it, the market will show demand for it. I'd hate to see the government mandate things like this however...I'm talking to you California.
Old 01-04-2014, 11:50 PM   #26
honeymooned in jamaica, the patio door in the hotel room had a switch on it that turned off the a/c if the door was open.
itsnotrequired is offline   Reply With Quote
Old 01-05-2014, 12:20 AM   #27
Rewards Points: 6,652
They do not open the walls during a renovation, unless they find signs of mold or damage.
Rarely do they just gut the whole structure, while it is in operation. If they did, they would loose thousands of dollars in revenue.
Majority is just cosmetic, ADA required, along with conforming with newer state standards for burn time on furnishings and carpets.
Old 01-05-2014, 05:12 AM   #28
An old Tradesmen
Many have off seasons. Which is when a wing will have planned renovations done.
Old 01-05-2014, 08:03 AM   #29
Rewards Points: 348
Cruise ships do that as well. Not that it matters as most of the time their A/C sucks anyway.
While it sounds like a good idea, there are too many here in the USA that don't like being told what to do regarding conservation. Call it a backlash at the way it has been forced down our throats by the anti-capitalism crowd masquerading as conservationists.
People here would simply get a second key.
herdfan is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
