Old 03-20-2013, 03:37 PM   #1
Kenmore Oven Error Code
We moved into a home with a black Kenmore double oven. It's great, however, about a year ago, an F7 error code came up which causes the oven to beep sporadically and the buttons to freeze up until you bang on the thing with your fist. We've let it go because it doesn't affect cooking, but now the beeping seems louder and more frequent. It's driving us nuts! I've heard that this is a computer board issue and can be bypassed with cleaning and disconnecting/reconnecting the ribbon wire.
I'm hoping someone out there has dealt with this and can give me some advice. I do have one question... and it seems stupid. Should I turn off the breaker before disconnecting and reconnecting any wires inside of the oven? Will that make a difference or not? Thanks to anyone who can help!
Katigan is offline   Reply With Quote
Old 03-20-2013, 04:14 PM   #2
Absolutely !
Here is a paper on the F7 code.
http://fp1.centurytel.net/Powerman/D...%20Problem.pdf
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Katigan (03-20-2013)
Old 03-20-2013, 05:13 PM   #3
Thank you for that link! I did turn the breaker off before disconnecting and reconnecting the ribbon wire. The only reason I asked was because I was hoping I didn't have to get at our out-of-the-way, unlabeled box. The error is gone, but I suspect it will be back soon, since many people have this problem. The insulation trick will definitely come in handy!
SCARY oven fire! Why did it burn? Beth777 Appliances 63 01-20-2013 07:55 PM
Kenmore Oven Broiler Kaput...need top fix downdraft Appliances 11 06-17-2012 12:11 AM
Kenmore Oven Element Arcing Valerie1960 Appliances 2 01-30-2012 09:03 AM
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 07:45 AM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 05:45 PM
