Keeping 3 Gang Boxes From Moving - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 02:13 PM   #1
Rewards Points: 337
keeping 3 gang boxes from moving
Okay, re-doing the kitchen, what I want to avoid is the outlets flexing in and out on the 3 gang boxes. The outlet next to the stud is fine but it always seems that the outlet furthest away flexes a bit. There is no way to put a stud there on the opposite side. What about using gorilla glue t attach blocking to the back of the box so it's hitting the OSB sheathing that would prevent it flexing back when pushing in a plug.
Also, the upper and lower drywall pieces seam right in the middle of the outlet. would I help add rigidity by placing a 6" piece of 1x vertically and screwing onto that? Or will drywall tape make it fine.
thanks!
titan7 is offline   Reply With Quote
Old 08-31-2010, 02:34 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
The 3 Gang Wallplate against the drywall should prevent should prevent flexing.
http://www.amazon.com/Leviton-80411-...3282556&sr=8-1.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-31-2010, 04:22 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
The 3 gang box should have a tab with a screw hole on the oppiste ends from the nails.
I just scew a small peice of 2x4 to the tab, and let it rest against the osb.
When the sheetrock is added, the box should not move.
Old 08-31-2010, 04:22 PM   #4
Electrician
Rewards Points: 802
Make a horzontal shelf out of 2x4 and screw the boxes into that as well as into the vertical stud.
darren is offline   Reply With Quote
Old 08-31-2010, 04:26 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Use a decent size block so all the pressure (on the back wall) is not applied in one small spot. I don't know about Gorilla glue though. I generally use something like PL200 construction adhesive.
Old 08-31-2010, 07:39 PM   #6
joed's Avatar
Rewards Points: 13,728
These boxes are for metal studs but You could use them. They have supports on them to rest on the drywall.
http://www.tnb-canada.com/en/catalog...xes_18_eng.pdf
Old 08-31-2010, 10:23 PM   #7
Rewards Points: 337
Thanks, I will take the dry wall section off and do this. We have not taped yet ; )
Old 09-01-2010, 04:26 PM   #8
Rewards Points: 337
If I drill a screw from the inside will that now create a potential electric hazard since there is now a grounded metal fastener on the inside of the box? Would it be a code violation? Ie. the head or the screw cuts the plastic coating on a hot wire?
The suck is this 3 gang box attaches with 2 recessed screws on side. there is no recess on the left so I would just have to drive it in at a angle.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 09:46 AM
Increase to double gang boxes... jamiedolan Electrical 20 10-17-2008 12:21 PM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 12:05 PM
Gangable old work boxes kornbln Electrical 2 05-27-2008 05:50 AM
