-   -   Karcher pressure washer (http://www.diychatroom.com/f18/karcher-pressure-washer-70343/)
fragrant_fred 05-02-2010 10:00 AM
I have a Karcher pressure washer that has stopped working probably due to problem with the Inco Sintex 45S C3D capacitor. The case is plastic and considerably swollen. 16uF, AC425V B 25/85/21 AC450V 25/85/21 and AC 500V D 25/85/21. 50/60 Hz It is 70mm by 35mm in size with two 6.3mm terminal at the top, made in Italy. Has anyone ideas where I can purchase another. As in a previous query the motor tries to start but only moves a little, yet it spins quite freely when turned by hand. The body of this capacitor is obviouly swollen through heat.
huck 05-02-2010 10:30 AM
Graingers probably will have the right one,or at least a comparible replacement
Huck
kennzz05 05-02-2010 11:09 AM
all you need to ask for when getting a replacement is 16 microferad 470 volt run cap. your probably going to have to use a 15 though as 16 is a weird size
mpoulton 05-03-2010 11:47 PM
Most likely any voltage rating 300V or higher will work fine, and capacitance +/- a few uF or so should be fine too. You will not find an exact replacement.
ric717 05-19-2010 08:53 PM
Hi i got the same machine with the same problem.I rang Karcher and you can buy a new capacitor for around $45 , now to buy a new machine,Super cheap spares have one similar for $89 not worth it spending that much on a capacitor and perhaps it wont work..
kerry42 05-20-2010 05:54 AM
You can try ( PressureParts.com ) they may have what you are looking for . Kerry
sparks1up 05-20-2010 10:03 AM
I googled 16uf motor capacitor and got lots of listings! Here is just one link!
http://www.google.com/products?clien...ed=0CDgQrQQwAg
joed 05-20-2010 10:37 AM
That a pretty good profit. $45 for $5 part.
rburke65 05-20-2010 03:36 PM
I don't think that it should cost anywhere near $45!
