Kamakazi Lamp Causes Upset Anf Frustration - Electrical - DIY Chatroom Home Improvement Forum
Old 02-01-2014, 09:40 PM   #1
Question
Kamakazi lamp causes upset anf frustration
One of my desk lamps took a dive off of a set of shelves in to a pile of dirty laundry today. When it landed, the light went out. Upon further inspection, i discovered that the light bulb wasnt broken, and that the two plastic pieces of the socket that were supposed to be screwed together were chipped, but easy enough to reattatch. I then plugged the lamp in, and it worked just fine... but when i plugged it in where it had been pluggged in when it fell, it would not turn on. I plugged a candle warmer in to the same outlet, and it did not work either. I went to my electrical box and flipped every switch off and then back on, and the outlet still will not work. Please tell me i can fix this myself. I cant afford to pay someone to do it. Help!!!
stickchick11 is offline   Reply With Quote
Old 02-01-2014, 09:45 PM   #2
DIY staff
Rewards Points: 7,174
It sounds like the outlet was damaged---changing an outlet is not to difficult---a couple of screw drivers will do--are you interested in instructions?
Old 02-01-2014, 09:50 PM   #3
It sounds like a tripped GFCI. What room is the receptacle located in? How old is your home?
hacksawjiw is offline   Reply With Quote
The Following 2 Users Say Thank You to hacksawjiw For This Useful Post:
oh'mike (02-01-2014), plummen (02-01-2014)
Tags
broken , bulb , lamp , outlet , socket
Patio Post Lamp Wiring Perry401 Electrical 2 06-08-2011 04:21 PM
help with lamp wiring please profondorosso75 General DIY Discussions 1 11-07-2010 06:46 PM
Please Help with Outdoor Lamp/ Sensor hcjoak09 Electrical 2 12-16-2009 10:49 PM
Fluorescent lamp flickering Ash Electrical 11 08-03-2008 07:35 PM
