Just Need A Bit Of Information On What Size Subpanel To Install - Electrical - DIY Chatroom Home Improvement Forum
Old 08-25-2011, 05:02 PM   #1
Just need a bit of information on what size subpanel to install
Hi All,
You guys helped me out about 2 years ago so here I am again.
I have 4 size 2 wires running through (pvc water lines....idiots,) that go from a 30 amp breaker in our well house, out 900 feet to an unused well at the rear of our property.
I want to use the 4 wires, from that 30 amp breaker at about the 500 foot mark in the center of the property. The wires have been exposed at that location and I want to put in an outdoor panel, and then run wiring out to service 8 duplex outlets that will have lighting and in the winter each outlet would have a 1250-1500 watt horse trough heater. The wiring will no longer service that well. What size panel can I put out there, what size wiring to the outlets. The furthest outlet would be approx 600 feet from the sub-panel.
Thanks for your help.
Cyndi
cherokeestar is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
60 amp subpanel install mshaw2 Electrical 14 10-27-2010 09:05 AM
Subpanel location and size PhillyRyan Electrical 5 08-18-2010 03:49 PM
correcting existing subpanel in detached garage mtk Electrical 17 03-14-2010 01:49 PM
What size conduit to subpanel faromic Electrical 24 02-05-2010 01:15 PM
