Just Moved To Livermore, CA - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2014, 05:27 PM   #1
Just moved to Livermore, CA
I'm told the power available at the house from PG&E is "90 amp".
The panel that is now installed in the house has a total of 8 breaker slots, most of which are utilized by half-size breakers to get more circuits.
If I was going to have this panel ripped out and replaced with something more modern with more breaker space what would I have installed? As far as I know you get 100amp or 200amp panels for residential applications and that's about it.
Is installing a 100amp panel legal if the service is only 90 amp?
Many thanks for giving this a look!
Fortyniner1340 is offline   Reply With Quote
Old 03-22-2014, 05:47 PM   #2
Oso954's Avatar
Rewards Points: 772
Who told you the service from PG&E is only 90 amps ?
Are you sure they did not say that the house service is 90 amps ?
If you call PG&E, the service planner should be able to tell you what your drop is rated for.
There are a lot of 150 amp panels out there, not just 100 or 200's.
Oso954 is offline   Reply With Quote
Old 03-22-2014, 06:15 PM   #3
My inspector told me abut the 90 amp thing. He said it had to do with the wiring (direct burial) from the street into the house.
Guess I don't understand the distinction between PG&E service and house service. The discussion I remember had to do with upgrading the wiring from the street to the house which would require a backhoe and trenching across the street. Messy business.
Old 03-22-2014, 07:01 PM   #4
Oso954's Avatar
Rewards Points: 772
First thing, do NOT trust the home inspector comment. While he might know what he is talking about, many of them do not. They often attempt to apply NEC rules to POCO facilities. (NEC does not apply to the POCO (in your case PG&E)).
Assuming that you have direct burial cable, that is an oddball. PG&E standards call for conduit for underground service.
Call the service planner and let him know what you are thinking about, and see what he tells you. Last I knew, your service planer (or Project Coordinator) was located there in Livermore.
Old 03-23-2014, 12:59 AM   #5
Thanks very much. I'll follow up with my service planner.
Need advice on a wall that was moved. racer220 Building & Construction 5 10-25-2011 05:32 PM
The House We've Just Moved Into Eutopia Building & Construction 13 10-11-2011 07:39 PM
Can this wall be moved? Advocate Building & Construction 8 03-29-2011 12:09 AM
I moved an electrical outlet. luweee Electrical 2 06-08-2009 09:20 AM
Moved thermostat, now no heat GeauxCajuns82 HVAC 4 02-03-2009 08:36 PM
