For example, I have one power outlet on a wall. If I wanted to add another one on the same wall 10 ft' down, would I splice/solder the black/white line, add an extension (3rd line) to the other power outlet like this:
I'm just trying to see how a whole house is wired. Any good diagrams/instructions from the web?
Again, I am not doing any electrical work. I am just learning by myself.
Get Electrical Wiring Residential (Mullin - get one based on the 2008 NEC). And start reading. It is essentially a text book for electricians and is my bible for planning and executing good work.
If you are really interested in learning about this you need a more directed approach than surfing the web. The idea you have about splicing/soldering would not be ok for anything other than a few specialized situations. There is simply too much information for you to glean the right info by picking and choosing from what you find online.
IMHO the OP ought to go to a Home Center and pick up one of their books, which are short on Theory (and Code) and more direct. In other words, they "Cut to the Chase". Because at the present level, serious Textbooks won't do any good.:huh:!
llckll (Poster #1, Original Poster) You may be right about the method of splicing that you showed in the lower right corner of the illustration, that it was used in "Knob-and-Tube" wiring. It is also called the "Western Union" splice. It is no longer used today. My father showed me this method of splicing (which he used himself) Some years ago!:thumbsup:!
Either the one shown in the illustration on the lower left. (Pigtailing. Meaning connecting the NEW wire to the source and the existing wire). Another, is called DAISY CHAIN???! Connecting each subsequent receptacle to the terminals of the existing one. (Some people look down this method).:whistling2:!
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
