Just Installed New Electrical Box - Open Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 09:56 AM   #1
wixman's Avatar
Just installed new electrical box - open ground?
I just replaced an electrical box - it's a plastic cut in box. My tester is saying 'Open Ground' - is that ok for a plastic box? I've read that plastic boxes don't need grounding
wixman is offline   Reply With Quote
Old 01-30-2014, 10:01 AM   #2
seansy59's Avatar
Rewards Points: 258
Plastic isn't conductive...just stating the obvious...
What kind of cable is feeding the receptacle?
2 wire or 3 wire? Cloth covered? If it is a 3 wire, and you have no ground still...then your ground wire is fake...
If it is 2 wire, you cannot put a 3 prong receptacle in...it must be 2 prong, or a GFCI outlet labeled (No equipment ground)
If it is a fake ground, back to a 2 wire outlet...and check your other outlets...because someone might of done the whole house like that, which is dangerous...
You DO have the ground wire connected to the outlet ground, right?
seansy59 is offline   Reply With Quote
Old 01-30-2014, 10:02 AM   #3
Rewards Points: 13,446
What type wiring do you have and how many wires?
Was there a metal box with metal conduit before?
Old 01-30-2014, 10:09 AM   #4
wixman's Avatar
It was a 2 gang metal box before nailed to the stud with metal conduit. I'm pretty sure it's 2 wire, but I can double check. There's 2 black and 2 white coming in, and 2 short wires bridging across the receptacles. I noticed when old box was removed, and the power was back on my patio lights weren't working.
I don't know a great deal (anything) about electrical work
Old 01-30-2014, 10:12 AM   #5
wixman's Avatar
Oh and it's not cloth covered. This is in the room attached to our garage
Old 01-30-2014, 10:53 AM   #6
joed's Avatar
Rewards Points: 12,362
The metal conduit was the ground. Put a metal box back in and ground to the box. All should be well.
The Following 2 Users Say Thank You to joed For This Useful Post:
plummen (01-30-2014), Stubbie (01-30-2014)
Old 01-30-2014, 11:06 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
That has nothing to do with the box grounding. Just do as joed explained and be sure the metal conduit is fastened to the metal box properly.
Why did you change out the metal box to plastic ?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-30-2014, 11:28 AM   #8
wixman's Avatar
Thanks guys! I'll take care of this tomorrow. I guess I needed to replace the box, and wasn't aware of any difference between plastic and metal.
Old 01-30-2014, 03:23 PM   #9
wixman's Avatar
I did it! It says CORRECT now!
I can't tell you how happy this makes me!
Thanks!
Old 01-30-2014, 05:00 PM   #10
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You could have just used a bonding bushing if you wanted to use the plastic box.
Old 01-30-2014, 10:25 PM   #11
UAW SKILLED TRADES
Stubbie's Avatar
I thought about that but somehow I got the picture that he probably didn't have a plastic box that would accept conduit. He just had the individual wires exiting the conduit and then coming into the plastic box through a knock out tab or holding tab like on a carlon blue.
Stubbie
Old 01-31-2014, 12:10 AM   #12
wixman's Avatar
Correct!
Old 01-31-2014, 06:07 AM   #13
E2 Electrician
Yeah, guess i was fixated on the fact that you 'could' do it, but not how the OP 'had' done it...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Stubbie (01-31-2014)
Old 01-31-2014, 06:14 AM   #14
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm still wondering why he was replacing the box.
open ground power loss scooter91 Electrical 7 09-27-2011 11:16 AM
Electrical Panel - Ground Bar/Wiring and Safety cfreak Electrical 31 09-11-2011 08:10 AM
Moving electrical dryer - Ground gives off 'hot' signal markkuss Electrical 8 12-23-2010 01:22 PM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Above Ground Pool+Deck Electrical Install (Ontario, Canada) hecubus Electrical 5 08-02-2008 01:42 PM
