Just Got Started - Electrical - Page 6 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 11:07 PM   #76
JOATMON
ddawg16's Avatar
Rewards Points: 798
Originally Posted by k_buz View Post
Current codes would say that those would need AFCI protection, but that didn't take affect until 2008 or so.
Before that, no protection necessary...AFCI or GFI.
K....is it not just AFIC only for a bedroom?
ddawg16 is online now   Reply With Quote
Old 07-22-2012, 11:08 PM   #77
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Depends on the code cycle...
Old 07-22-2012, 11:19 PM   #78
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
2005 was simply bedrooms
2008/2011 include any recepts not GFI protected (basically)
2014 (rumored) to include lighting
(A) Dwelling Units. All 120-volt, single phase, 15- and
20-ampere branch circuits supplying outlets or devices installed
in dwelling unit kitchens, family rooms, dining
rooms, living rooms, parlors, libraries, dens, bedrooms,
sunrooms, recreation rooms, closets, hallways, laundry areas,
or similar rooms or areas shall be protected as described
by (1), (2), (3), or (4).[ROP 280, ROP 282a,
ROP 285]
Old 07-22-2012, 11:36 PM   #79
E2 Electrician
Lighting outlets were always required to be AFCI.. not sure why they had to add 'device' to the requirement. Guess they want to sell as many AFCI's as possible.
Seems to me they added 'device' to clarify that they want switches AFCI protected as well, since they don't fall under the definition of 'outlet'
Old 07-22-2012, 11:40 PM   #80
Rewards Points: 164
So...if i'm plugging in 4 t12 florescent fixtures on my ceiling of my shop.....they're supposed to be AFCI?
ryan50hrl is offline   Reply With Quote
Old 07-22-2012, 11:42 PM   #81
E2 Electrician
Your shop would most likely not be a dwelling unit. Also, it depends on what code cycle your state is on.
Old 07-22-2012, 11:44 PM   #82
E2 Electrician
Here is the 2005 NEC requirement of AFCI's... The graphic is incorrect though, because switches are not 'outlets' by definition, which I think is what they are trying to change in the 2014 by adding 'device' to the requirement.
Old 07-22-2012, 11:47 PM   #83
Master Electrician
My codebook is clear. Any wall finished with drywall, panelling. So on and so forth to within 450mm of the floor is a finished wall. I guess the ceiling doesn't matter so much. Wow that stinks about the afci's. I guess its only a matter of time before we get stuck with them outside the bedroom too.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-22-2012, 11:53 PM   #84
E2 Electrician
Some states are smart enough not to fall victim and incur extra expenses on home owners. Connecticut is one of those states, hence why were still on the 2005, and no rumors of taking on the 2014...
Old 07-23-2012, 07:59 AM   #85
Rewards Points: 712
Originally Posted by kontoose View Post
I always cut them off when I find them. They are good for initial organizing, when making up the panel...when left loose, but they ought to be cut off at the end - not tightened, and left.
(And inductive heating is a real issue).
How would a tie-wrap cause inductive heating??
Mark
busman is offline   Reply With Quote
Old 07-23-2012, 10:16 AM   #86
JOATMON
ddawg16's Avatar
Rewards Points: 798
Mark
Because the wires are bound together so tightly, the inner wires can't get rid of their heat....similar reason we have max fill limits for conduit....
Old 07-23-2012, 11:20 AM   #87
Rewards Points: 712
I agree that bundling conductors closely together makes them run hotter because it impedes heat dissipation, but that has nothing to do with induction.
Mark
Old 07-23-2012, 01:17 PM   #88
E2 Electrician
Let's no forget that you would have to 'bundle' for more than 24" to meet the definition of bundling...
Old 07-27-2012, 11:06 AM   #89
Rewards Points: 164
Ok......this look better? I know there's two knockouts in the top right that need to be filled....anything else?
Old 07-27-2012, 11:46 AM   #90
JOATMON
ddawg16's Avatar
Rewards Points: 798
Much better.....very nice in fact.....
I think you will agree that it will now be easier to work in that panel than the previous version....
My 5 year old composition roof started leaking boogiebuild Roofing/Siding 6 01-15-2011 08:40 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 10:41 AM
Started removing popcorn ceilings then found out there was 2% asbestos. Am I at harm? Peawhy Remodeling 15 12-30-2010 01:05 PM
Have you started your xmas decorations yet? StyleRoom Interior Decorating 2 12-02-2009 10:35 AM
Got started! rodsteryz Kitchen & Bath Remodeling 6 02-09-2009 01:51 AM
