Just Got Started - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 09:19 PM   #61
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by ryan50hrl View Post
well i've read back through some posts, some of which are quite old......and there were a few (i don't recall the post titles, but they were quite old anyhow) where people were running NM and it was instead "suggested" that they didn't run NM in interior areas and ran conduit instead....
Some people can't accept that its safe without some other means of protection, because they think people throw axes around their house, I seriously can't answer your question on why people think what they think, but I never use any other means of protection unless the NEC strictly addresses it.
Old 07-22-2012, 09:22 PM   #62
JOATMON
ddawg16's Avatar
Rewards Points: 1,822
I assumed that NM was the standard, as it is around here.....i've been in hundreds of homes (real estate broker) and I don't think i've ever seen one wired with anything but a vast majority of NM......just wondering if its different in different regions of the country and world?
That might be a local thing.....like in Chicago....there you have to use that armored stuff.....and it all has to be done by a licensed (union) electrian.....
NM is a great product...especially the newer stuff...protective cover is pretty tough...but easy to strip off....and slids through holes easy....
In my case, I used a lot of stranded because I had some runs that were about 75-80'....and not easy (translation, holes in the wall) to run. It was easier to install conduit in my new foundation that would get it to the existing house.
Boy...did I use a lot of stranded....almost 1000' of each color....but I do have a couple spare ckts tossed in....
Old 07-22-2012, 09:30 PM   #63
Rewards Points: 164
K.....thats what I kind of thought.....secondary question....i'm putting outlets on the joists in the ceiling of my shop. Ok to use the blue pvc nail on boxes?
ryan50hrl is offline   Reply With Quote
Old 07-22-2012, 09:35 PM   #64
E2 Electrician
Yes. That's fine.
Old 07-22-2012, 09:36 PM   #65
JOATMON
ddawg16's Avatar
Oh no.....now youv'e done it.....plastic vs metal......only thing worse you could do we be to ask how much......
Old 07-22-2012, 09:40 PM   #66
Rewards Points: 164
LOL......well my main concern is it code compliant.....not so much is it popular....
Old 07-22-2012, 09:40 PM   #67
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If your shop is in a basement or garage the receptacles have to be GFI protected.
Old 07-22-2012, 09:41 PM   #68
Rewards Points: 164
All my recepticals in the basement need to be GFCI? None currently are......
Old 07-22-2012, 09:45 PM   #69
JOATMON
ddawg16's Avatar
Ok....I'll 'try' to be serious for a moment.....
I like plastic because they are cheap and easy to install....but I only use them in my house for low 'stress' applications....i.e., light switches, regular outlets...etc.
Ceiling? If it's just for a smoke detector...fine...but for a ceiling light or ceiling fan? Metal.
I used plastic boxes for my garage outlets. In retrospect, I wish I had used metal. My garage use involves tools with slightly heavier cords....which means they ALL have the ground pin...takes a bit more force to get them in and out and you can see that plastic box moving just a bit.
Old 07-22-2012, 09:49 PM   #70
k_buz's Avatar
Current codes dictate that all 120v rec in unfinished basements be GFI protected.
Old 07-22-2012, 09:51 PM   #71
Rewards Points: 164
What if its in a finished section?
Old 07-22-2012, 09:56 PM   #72
k_buz's Avatar
Current codes would say that those would need AFCI protection, but that didn't take affect until 2008 or so.
Before that, no protection necessary...AFCI or GFI.
Old 07-22-2012, 09:57 PM   #73
JOATMON
ddawg16's Avatar
Covered walls and anything other than bare concrete for a floor.
In other words, GFI's are required anywhere there is concrete or dirt on the floor. Concrete is actually pretty conductive....
Most 'unfinished' basements have concrete floors....and bare walls are concrete or block. When you 'finish' a basement, most of this is usually covered.
Old 07-22-2012, 10:01 PM   #74
Rewards Points: 164
Good to know....i'll keep that all in mind....
Old 07-22-2012, 10:07 PM   #75
E2 Electrician
Im going to disagree with you, I would call painting the walls a finished room, therefore no GFCI protection required. Exposed concrete or not... Lets not throw in our own opinions on what 'we' think the code should require.
My 5 year old composition roof started leaking boogiebuild Roofing/Siding 6 01-15-2011 07:40 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Started removing popcorn ceilings then found out there was 2% asbestos. Am I at harm? Peawhy Remodeling 15 12-30-2010 12:05 PM
Have you started your xmas decorations yet? StyleRoom Interior Decorating 2 12-02-2009 09:35 AM
Got started! rodsteryz Kitchen & Bath Remodeling 6 02-09-2009 12:51 AM
