Old 07-19-2012, 04:33 PM   #16
Just got started
Originally Posted by Jim Port View Post
Yes to the red circle.
I would have also routed the white and bares the shortest route across the top of the panel.
AHHHH.....now i'm going to have a complex about an ugly panel....
ryan50hrl is offline   Reply With Quote
Old 07-19-2012, 05:14 PM   #17
the Musigician
DangerMouse's Avatar
Just got started
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-19-2012, 05:31 PM   #18
JOATMON
ddawg16's Avatar
Just got started
If it makes you feel any better.....been there....
BTW....a little suggestion.....
Use a black permanent marker and write on the sheath what the run is for. 2 Years from now when you open the panel back up....you will be glad you did it.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 07-19-2012, 05:35 PM   #19
Just got started
I've fired up my wifes P-Touch label maker and am going to identify them....
Old 07-19-2012, 07:32 PM   #20
J. V.'s Avatar
Just got started
The MLO panel is compliant in the the structure. No main required.
OP. Jim is talking about aesthetics regarding the cable on the right. Leave it like it is, and its DIY. Re-route it and it will look more professional.
Old 07-19-2012, 09:17 PM   #21
Electrical Contractor
kbsparky's Avatar
Just got started
Open knockout on top right side. You need to plug that hole up.
-KB
Old 07-19-2012, 09:33 PM   #22
E2 Electrician
stickboy1375's Avatar
Just got started
I'll give you an uplifting opinion, Although myself I would cut the insulation back, the panel looks decent, and as already stated, re identify the white conductor on the breaker, (because obviously nobody in intelligent to realize that it is a "HOT" conductor) anyway...
Buy yourself a set of these for stripping the jacket off NM cable...
Old 07-19-2012, 09:59 PM   #23
Just got started
I've got a set......i just need to strip it back further....
Old 07-19-2012, 10:11 PM   #24
E2 Electrician
Just got started
Doesn't look like you used them. lol
Old 07-19-2012, 10:14 PM   #25
Just got started
Nope.....sure didn't........but that doesn't mean i don't have a set!!!!!
They just might be the same place as my needle nose pliers right now.....
The Following User Says Thank You to ryan50hrl For This Useful Post:
Evstarr (07-23-2012)
Old 07-19-2012, 10:15 PM   #26
E2 Electrician
Just got started
No biggy, just trying to make your life easier.
The Following User Says Thank You to stickboy1375 For This Useful Post:
ryan50hrl (07-19-2012)
Old 07-20-2012, 01:07 AM   #27
Just got started
Where's the feeders...? They usually go in first, so that they're tucked away at the back, out of the way.
(Apart from the above mentioned issues such as the missing K.O. seal - which I feel you left out as a red-herring - and the 14/2 using the neutral as a hot...and the sheathing being too long (i.e., "all conductors, shall be identified within three inches of entering, or exiting enclosures").
Your panel wiring is inconsistent, i.e., different lengths of stripped conductors; some conductors protrude out of the back side of the neutral bus, others don't. (It would be uncertain if you had tied down a conductor partly over the insulation).
All finished screws (i.e., screws that have been terminated over the conductor) need to be left with their slots in the horizontal plane, and if they're Phillips, the the "+" needs to be left as shown...otherwise, how would you know - to within a slim percentage of error - whether or not the conductor has been properly terminated at it designated torque...?
(None of you have worked government - right). Mind you, for a beginner, the panel's wiring sloppiness is...what it is. Good try, though...but call your electrician buddy to check over the work please. I don't want to see you on News At 10...
kontoose is offline   Reply With Quote
Old 07-20-2012, 07:56 AM   #28
Just got started
Your's looks better than this:
hammerlane is offline   Reply With Quote
Old 07-20-2012, 07:57 AM   #29
Just got started
But not better than this:
Old 07-20-2012, 08:15 AM   #30
E2 Electrician
Just got started
Although nice, it looks expensive, and not everyone can afford art work.
My 5 year old composition roof started leaking boogiebuild Roofing/Siding 6 01-15-2011 08:40 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 10:41 AM
Started removing popcorn ceilings then found out there was 2% asbestos. Am I at harm? Peawhy Remodeling 15 12-30-2010 01:05 PM
Have you started your xmas decorations yet? StyleRoom Interior Decorating 2 12-02-2009 10:35 AM
Got started! rodsteryz Kitchen & Bath Remodeling 6 02-09-2009 01:51 AM
