Just Got Started - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 02:09 PM   #1
Rewards Points: 164
Just got started
Ok guys, I just got started putting in my new sub panel, anyone see anything wrong yet?
Just got started-image-3860244250.jpg   Just got started-image-2657353444.jpg   Just got started-image-4140370626.jpg
ryan50hrl is offline   Reply With Quote
Old 07-19-2012, 02:21 PM   #2
Licensed electrician
Rewards Points: 1,038
You only need the sheath to extend 1/4" into the box.
The white on the two pole breaker needs to be re-identified as a hot.
I also would have routed the cable on the right down the right side gutter.
ryan50hrl (07-19-2012)
Old 07-19-2012, 02:31 PM   #3
Rewards Points: 164
Thanks Jim question on the sheath, do I need to pull those back out and cut them back further or should I just do it on the remaining ones, I guess the question is is it a code violation or just an ugly violation
Old 07-19-2012, 02:38 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 840
I don't see a main breaker....I believe your limit is 6 breakers.
Old 07-19-2012, 02:45 PM   #5
Rewards Points: 164
Oh? I'm confused as to why there would be subpanel sold with Eight spots, 16 circuits labeled on it..... I was planning on using all eight spots is that a problem?
Old 07-19-2012, 02:53 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 840
Without a main disconnect....yea.....it will be a problem....I got dinged by my inspector on the sub-panel in my garage. I had 7 breakers. He said "Disconnect one".....then on the way out the door he said softly "You can reconnect it later if you want.".
The basic intent of the rule is that if you have to shut everything off quickly, anything more than 6 breakers may take too long.
Hopefully one of the experts will chime in...but I believe you can put in a larger breaker and backfeed it. That would be your main breaker .
Old 07-19-2012, 02:58 PM   #7
Rewards Points: 164
I was under the understanding that as long as this was in the same structure, which it's in the basement next to the main panel about 20 feet away that it was okay. But that if it was in the garage then it had to have a main breaker
Old 07-19-2012, 03:02 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
You only need a main disconnect if the sub is in a remote building. If in same building as main panel it is not required.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following 4 Users Say Thank You to rjniles For This Useful Post:
brric (07-20-2012), J. V. (07-19-2012), mpoulton (07-19-2012), stickboy1375 (07-19-2012)
Old 07-19-2012, 03:14 PM   #9
It makes it harder to work with the conductors still in the sheath. The code does require at least 6" of free conductor in a box.
Old 07-19-2012, 03:17 PM   #10
Rewards Points: 164
I did notice that........i'll measure more carefully next time......
Old 07-19-2012, 03:26 PM   #11
Rewards Points: 164
Any particular way it needs to be done to meet the requirement?
Old 07-19-2012, 03:33 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 144
A black or red sharpie or piece of tape or some black/red paint.
The Following User Says Thank You to jbfan For This Useful Post:
Old 07-19-2012, 04:11 PM   #13
Rewards Points: 164
Jim,
I'm assuming your talking about this wire to the circled location?
Old 07-19-2012, 04:27 PM   #14
Semi-Pro Electro-Geek
Rewards Points: 2,860
The 6-disconnect rule applies only to services. So unless this panel serves a separate structure, you can have as many breakers as you want in there.
mpoulton is offline   Reply With Quote
Old 07-19-2012, 04:30 PM   #15
Yes to the red circle.
I would have also routed the white and bares the shortest route across the top of the panel.
My 5 year old composition roof started leaking boogiebuild Roofing/Siding 6 01-15-2011 08:40 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 10:41 AM
Started removing popcorn ceilings then found out there was 2% asbestos. Am I at harm? Peawhy Remodeling 15 12-30-2010 01:05 PM
Have you started your xmas decorations yet? StyleRoom Interior Decorating 2 12-02-2009 10:35 AM
Got started! rodsteryz Kitchen & Bath Remodeling 6 02-09-2009 01:51 AM
