Just Curious - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 06:41 PM   #1
Question
Just Curious
Can I step up the amps output from a generator. I believe I can step up the voltage via a step up transformer but how about the amps?
Traveler is offline   Reply With Quote
Old 03-05-2011, 07:08 PM   #2
V=IR. The current you get depends on the voltage and the load. The transformer does not magically add power, so will not be able to get out more power than you put in.
joshxdr is offline   Reply With Quote
Old 03-05-2011, 07:16 PM   #3
Thanks for your reply. I have a generator that supplies 3500 watts at 115 volts and want to increase its output if possible. Can I not step up the power in some way as you can the voltage?
Old 03-05-2011, 07:24 PM   #4
I=E/R
a7ecorsair's Avatar
Power is power. If you feed a transformer with a certain power and the transformer is 100% efficient you will get the same power out.
Power = Voltage x Current. If the transformer is a 1:2 step-up, the output voltage will double and the current will be 1/2.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Traveler (03-05-2011)
Old 03-05-2011, 08:35 PM   #5
Rewards Points: 506
Deleted.
jlmran is offline   Reply With Quote
Old 03-05-2011, 10:03 PM   #6
joed's Avatar
Rewards Points: 11,614
The simple is NO YOU CAN NOT. If you need more watts you need a large generator.
Old 03-05-2011, 10:21 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Short and sweet answer is no due the generator wattage size that is your limit there.
That is the stumbling block there if you need more wattage you will have no choice but get larger generator unit.
Merci.
Marc
Old 03-06-2011, 02:07 AM   #8
Thanks. I could not see any way except a bigger generator to get what I wanted. I just wanted to be certain.
curious cracks in drywall, plus door sag bleedpurple Drywall & Plaster 13 07-04-2009 04:01 PM
Curious Bocolo Electrical 4 02-16-2009 08:14 AM
Dumb Neutral wire question, just curious. helpless handyman Electrical 14 12-28-2008 01:48 PM
just curious - PVC primer amakarevic Plumbing 7 03-24-2008 07:26 PM
Curious minds gotta know Darylh Building & Construction 4 06-11-2006 12:20 PM
