Old 10-26-2011, 01:28 PM   #16
Code05's Avatar
Just curious
Originally Posted by Billy_Bob View Post
P.S. The difference is that a MWBC in a home is not using 240 volts whereas the 240 volt circuit is.
And I am not a circuit breaker guru, but it is my understanding that a 240 volt breaker is internally connected, so if one trips, the other trips as well????
Whereas for MWBC, it would be two separate 120 volt breakers which have a tie-bar added????
I tried searching for this info several years ago, but couldn't find anything. Anyone know? Does not matter? Does matter?
A 2 pole breaker has an internal common trip, yet there is no requirement to use one for a dryer or a range. 2 single poles and a handle tie is legal.
Code05 is offline   Reply With Quote
Old 10-26-2011, 01:47 PM   #17
Just curious
Thanks!
That did it! The word "common".
I googled common trip breaker and found all sorts of stuff on this.
(Took me a few years, but better late than never. I was searching for internal trip...)
Anyway I found there is a difference between a double pole breaker with an internal or external "common trip", and two single pole breakers connected with an add-on tie-bar.
With the common trip, if one breaker trips, the other trips as well.
Billy_Bob is offline   Reply With Quote
Old 10-26-2011, 01:52 PM   #18
Code05's Avatar
Just curious
Thanks!
Correct.
Old 10-26-2011, 02:00 PM   #19
Semi-Pro Electro-Geek
Just curious
I'm not sure that's true. Do you have a code reference? 210.4C Ex. 2 seems to disagree.
mpoulton is offline   Reply With Quote
Old 10-26-2011, 02:16 PM   #20
Code05's Avatar
Just curious
Exception No. 1: A multiwire branch circuit that supplies
only one utilization equipment.
Exception 1: A multiwire branch circuit can supply line-to-line utilization equipment, such as a range or dryer.
From here:http://ecmweb.com/nec/code-basics/el...circuits_part/
Old 10-26-2011, 09:38 PM   #21
Just curious
A 120/240 volt "multiwire branch circuit" is electrically the same as and constructed in the same way as a "240 volt circuit with neutral" to serve an appliance such as a clothes dryer with both 240 volt and 120 volt components.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Just Curious Traveler Electrical 7 03-06-2011 02:07 AM
Who prefers to refurbish old furniture/appliances over buying new (just curious) Snav General Discussion 5 08-24-2009 04:06 PM
just curious... what DIY would you NEVER attempt diy'er on LI Building & Construction 25 07-30-2009 12:24 AM
just curious - PVC primer amakarevic Plumbing 7 03-24-2008 07:26 PM
Curious minds gotta know Darylh Building & Construction 4 06-11-2006 12:20 PM
