Just Bought A House... Need Electical Advice... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2009, 10:35 PM   #16
If you decide to stay with 100a service at least install a 200a panel instead of a 100a panel. At least that way if you do decide to go to 200a you won't need to change another panel
My oil boiler is over 20 years old, still running
My wife's grandmother just had her system replaced - 50 years old
Ours is due to be replaced per our Oil guy ( I agree)
Around here Oil heat is still cheaper then electric
Even before oil prices dipped
Do you have Hydro electric power - less expensive?
Old 04-18-2009, 09:47 AM   #17
Ok, just spoke to the electrician.
Apparently, it's illegal to install a 200amp panel with a 100amp service here in Quebec, so he won't do it.
I'm not sure what it would cost to heat that house with electric only, so I can't say whether it would be less expensive or not.
To give you an idea...
Hydro electric costs around here are:
$0.054 per kWh for the first 30 kWh per day
$0.0733 per kWh for remaining consumption.
Oil costs for this past winter at that house were approximately $600.
Will you be replacing yours with an oil or electric furnace?
pure_energy1 is offline   Reply With Quote
Old 04-18-2009, 10:10 AM   #18
Electrical Contractor
kbsparky's Avatar
Apparently, it's illegal to install a 200amp panel with a 100amp service here in Quebec, so he won't do it....
IF you take a so-called 200 Amp panel, and replace the main breaker with a 100 Amp one, you now have a "100 Amp" panel.
Easy to upgrade to a 200 Amp later by simply replacing the service cable/drop and then swapping out the main back to a 200. You won't have to replace the whole panel next go-around.
Old 04-18-2009, 12:30 PM   #19
If a gal. of oil puts out 115,000 BTU, then
115,000 BTU = 34 kwh for electric heat = $2.40
115,000 BTU = 11 kwh for heat pump heat = 80 cents
Virtually all of the elec. energy into your house goes into heating that house.
The clearing time for fuses and the trip curves for breakers are tailored to protect the wiring, assuming the fuses and breakers still meet factory spec's.
The insurance companies may be nervous about other problems correlated with fuses vs. whatever risks the use of breakers present. The fuses themselves may be blameless, and fuses [being simpler] may actually be more reliable.
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
Music to the rest of the House Advice gregt848 Home Theater 12 01-25-2009 12:03 PM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 01:40 PM
Old house new problems: I need advice SandyD Building & Construction 3 09-14-2007 10:53 PM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 09:14 PM
