Just Bought A House... Need Electical Advice... - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2009, 01:40 PM   #1
Just bought a house... need electrical advice...
Hello,
I just bought a split-level home that was built in 1977.
The electrical panel currently consists of a fusebox with a 100 amp service.
There is a thermopump that provides heating and AC. Additional heating is provided via an oil furnace when temperatures dip below -12c.
For obvious reasons, I'm looking at having an electrician change the fuse panel over to a breaker panel. However I am unsure of which way to go.
Being on a limited budget, I was originally going to replace the panel for a breaker panel, and retain the 100 amp service (estimated cost of ~ $900 Cdn). However the electrician thought that it would be wiser to upgrade to a 200 amp service, (estimated cost of $1850, + additional $300 from my electric company to change to 200 amp service from the pole), in case I decide down the road to change over to an electric furnace.
I'm trying to weigh the benefits of moving over to a 200 amp service since I have an oil furnace. The oil furnace and oil tank date back to 1996.
So my dilemma:
- Should I retain the 100amp service, and stick with an oil furnace?
- Should I upgrade to a 200amp service, just because..?
- Should I upgrade to a 200amp service and down the road change over to an electric furnace? <-- Will this yield any savings vs. an oil furnace? The cost to install an electrical furnace alone would be around $2000.
Thank you for any guidance.
pure_energy1 is offline   Reply With Quote
Old 04-17-2009, 03:13 PM   #2
Licensed Pro
I'll throw out another option... do nothing. There is nothing wrong with fuses other than the inconvenience of having to replace them instead of resetting. Changing to breakers just because there are fuses there now, without any other upgrades is rather pointless in my opinion. Are there other reasons you are considering doing this?
Old 04-17-2009, 03:17 PM   #3
The main reason I am considering this is because my insurace broker is giving me grief about there being a fuse panel. By having a fuse panel, I don't qualify for better coverage, and my insurance is considerably more expensive.
But yes, as you mentioned, I am considering just leaving it as it is for now until I decide what route I'd formally like to go...
Old 04-17-2009, 03:32 PM   #4
Just swap out the panel if you must, you don't need to upgrade to 200. Well, you could have a load calculation done.
rgsgww is offline   Reply With Quote
Old 04-17-2009, 04:04 PM   #5
How soon will the upgraded panel pay for itself in saved insurance premiums?
If there is less than a 100(900/2150) = 44% chance or less you'll need 200A, don't do it.
Oil furnace lifetime = ~20 years.
What do you pay per kwH for elec. and for oil? What is the Heat Value for your oil?
Benefit of doing that = ?
Lifetime of an elec. furnace= ?
Old 04-17-2009, 04:23 PM   #6
I'm at about 95% load right now with the current installation.
In about 3 yrs.
But should I take into account the age of the oil furnace? It's about 13 yrs old now. What's the life expectancy of an oil heater anyways, without taking into account repairs like replacing a burner and such?
I ask, because if it comes time to change the oil furnace, it may be a better option to look into an electric furnace (also cheaper I think?) when the time comes; which means I would need to rip out a perfectly good 100 amp panel and spend over $2k to put in a 200 amp service and panel...
I'm also trying to look into the future and prepare accordingly, as well as favour any additional value to the home itself.
...and then there's other things that have to be corrected in the house, such as:
- replacing old wood fence
- lay ceramic tiles in kitchen
- replace floating floor on main floor in favour of hardwood floors
- install floating floor from main floor in basement
- replace original inefficient single-pane windows in living room
I guess I just don't know what would be the best way to go about it all...
Old 04-17-2009, 04:33 PM   #7
". . .we now sell our homes and move an average of every six years. . ."
http://images.google.com/imgres?imgu...a%3DN%26um%3D1
Old 04-17-2009, 04:36 PM   #8
lol...
Old 04-17-2009, 04:58 PM   #9
Rewards Points: 81
If you just replace the main fuse panel with 200 amp main panel with 100 amp breakers installed (or make the new main a 200 amp sub-panel feed from a 100 amp disconnect main panel) I would think that would keep you closer to the original bid, and position you to upgrade to 200 amps later.
Does that make sense?
daxinarian is offline   Reply With Quote
Old 04-17-2009, 05:29 PM   #10
Electrician
Rewards Points: 760
Why is your insurance charging you more because you have fuses, i would question this. In my opnion fuses are just as safe as breakers. Of course any idiot can put a bigger fuse in but then the inusrance company can tell you to go fly a kite when your house burns down. But you can also put in a bigger breaker and have the same problem.
I would get a few more prices on doing just a panel upgrade. Do you have a fuseable disconnect between your meter and fuse box. If so you could consider getting a 200A main breaker panel and install it after your disconnect. Then your panel will be protected by your 100A fuseable disconnect and your 200A breaker will serve no real purpose. Then in the future if you upgrade you will already have the panel.
darren is offline   Reply With Quote
Old 04-17-2009, 07:47 PM   #11
220/221 is offline   Reply With Quote
Old 04-17-2009, 07:54 PM   #12
If your going to replace the panel, do it all at one.
Old 04-17-2009, 07:56 PM   #13
Learning by Doing
Leah Frances's Avatar
So the way I think about it... when have you ever needed less electricity than you thought...
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-17-2009, 10:28 PM   #14
Yeah, I think I follow. I'll see with the electrician if this is possible.
It seems to be the norm here in Quebec. I called several insurance companies. Many didn't even want to insure a house that still uses fuses, and those who did would do so with a limited coverage instead of all risks.
Hehehe... Yeah.. I'm contemplating it.
Old 04-17-2009, 11:03 PM   #15
Electrical Contractor
kbsparky's Avatar
Why is your insurance charging you more because you have fuses....
Several reasons:
  • Most houses with fuses in them already have larger fuses installed than the wiring is designed for
  • You have the electrical hazard of live exposed parts with fuse boxes without removing the cover(s)
  • Circuit breakers can trip faster than a fuse blows due to high-inrush current with some short circuit conditions. Fuses actually have to get hot to blow -- melting or burning of the fuse element is necessary.
  • Insurance companies keep track of such things, and have proven by claims histories that houses protected with breaker panels have fewer claims due to electrical fires than those with old fuse boxes, etc.
I have had some customers change out their panel due to insurance company surcharges of 50% or more, or dropping the policy altogether.
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 04:06 PM
Music to the rest of the House Advice gregt848 Home Theater 12 01-25-2009 01:03 PM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 02:40 PM
Old house new problems: I need advice SandyD Building & Construction 3 09-14-2007 11:53 PM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 10:14 PM
