Just Bought A 1946 House, Redoing Kitchen, What Electrical Fixes/upgrades Needed? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 12:17 AM   #16
Originally Posted by Scuba_Dave View Post
If you are replacing the cabinets I would cut out some sheetrock behind the cabinets & drill thru the studs
Just a thought
My house is also top wired for almost everything
I certainly am replacing cabinets. I guess I'm just gunshy about doing such things, though. Every hole and ding seems like a separate project even when it might save me time and money in the long run. This is my first house, in case you can't tell.
Probably, I'll take a cue from the existing wiring and just drop down for each outlet from the attic. I would/will definitely go from the basement for any new circuits though. It just seems easier...no mucking around with insulation, etc.
TomServo is offline   Reply With Quote
Old 09-20-2009, 10:48 AM   #17
My last house didn't have much insulation, & poorly installed
Last kitchen was a total gut & redo (except ceiling)
This kitchen will be walls only, insulation is only R7
But only 1 exterior wall & that borders the new garage
Old 09-21-2009, 03:10 AM   #18
Arrow
Here's a good example of the existing wiring
I forgot I had a couple photos of the attic. This pic is pretty representative of the wiring up there. Here we see two runs of cloth wrapped wiring that I believe are for lighting and/or outlets in the dining room/kitchen. There actually isn't a whole load of this stuff visible up there, but I wonder how much I don't see that might be under the insulation or running along joists, etc.
I *think* (and hope) that all the wiring in the attic is run from the basement breaker box in a central location. It would seem to make replacement a good bit easier. I can't see it being done any other way, but I just haven't been up there looking at electrical in particular.
Should I be worried about this type of wiring as a fire/safety hazard? I don't like to see it unsupported and having deteriorated enough to stain the insulation (two runs crossing each other, no less).
Just bought a 1946 house, redoing kitchen, what electrical fixes/upgrades needed?-attic_wiring.jpg
Old 09-21-2009, 07:48 AM   #19
The runs crossing each other is OK, as long as the insulation on the wiring isn't crumbling
If you don't walk up there too much I wouldn't worry about it
Most of my wiring is between the ceiling & the ceiling joists
The ceiling joists have strips running across them, then ceiling board installed
Since I am renovating the 2nd floor I have removed all the cloth wiring that I could access
2nd floor was finished & I have not taken the finished floor up
So the only thing left is the 1st floor, basement completed already
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 10:20 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
