Old 06-04-2011, 05:03 PM   #1
Juno Gimble 440 recessed trim--no instructions help
My contractor installed Juno TCR1 housings for me for an area over a shelf. I bought Juno 440 trim and 16 PAR bulbs as instructed. NO instructions came with the trim and I cannot for the life of me figure out how the bulb connects to the trim. It looks like the bulb has a ridge on it and the trim has a spring mechanism holding a piece of glass, I have tried numerous times to see if the bulb fits on top of the glass but cannot get it to. Help!
Christine32 is offline   Reply With Quote
Old 06-04-2011, 07:03 PM   #2
Master Electrician
I believe you need a Juno GU10-WHIP with that trim ring. It is an adapter that screws into the socket in the housing, has two wires attached to another socket which holds the lamp and attaches to the trim.
http://www.junolightinggroup.com/Sea...alue=GU10-WHIP
brric is offline   Reply With Quote
Old 06-04-2011, 08:52 PM   #3
Thanks! I think you are right because there are flat MR16 bulbs that hook into the GU10-WHIP and they have a ridge that looks like it sits in the trim.
recessed lighting (6" Juno IC with 261w-wh wall wash trim) paul breyer Electrical 1 05-28-2011 03:42 PM
installing recessed lighting trim lwb1 Electrical 1 09-01-2010 09:43 PM
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 05:30 PM
choosing right bulb and trim kit combo for recessed windowguy Electrical 3 11-29-2009 04:17 PM
How to remove trim from Halo recessed lighting?? rdiggidy Electrical 6 08-17-2009 08:37 PM
