Junctions In Receptable Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 02:48 PM   #1
Rewards Points: 141
Junctions in receptable box
Provided there is enough room in the box, is it okay to run two power outs or powers through from one single receptacle or outlet box?
DiegoJames is offline   Reply With Quote
Old 07-04-2013, 02:57 PM   #2
joed's Avatar
Rewards Points: 13,752
You can run as many wire/cables as will fit in the box according to the wire fill calculations.
The Following User Says Thank You to joed For This Useful Post:
DiegoJames (07-04-2013)
Old 07-04-2013, 03:10 PM   #3
MarginallyQualified
Rewards Points: 2,464
Try to plan the work so that the feed can go from point A to B to C to D etc
...rather than from point A to B *and* C *and* D
Old 07-09-2013, 08:29 PM   #4
Rewards Points: 141
Yes, TarheelTerp. I know your suggestion is preferable regarding A to B to C to D etc. This is an old house and there is more branching going on instead of A to B to C to D etc. than would be intentionally designed if an entire fresh start was made Though this is the only place in the house where two branches leave an outlet and for some reason it makes me nervous. Ah, actually there's going to be one more in another place where I'm adding a branch off an already through switch box. The individual circuits are not overloaded with too much on one line, and the boxes are at least just big enough, but should it still make me nervous!
Old 07-09-2013, 08:31 PM   #5
Rewards Points: 141
(All the other multi-branches, breaking nice in line schemes, are in very spacious junction boxes in the basement.)
Old 07-09-2013, 08:32 PM   #6
Rewards Points: 141
in-line (correction)
Installing new outdoor receptable, any code reqs? NewHomeDIYGuy Electrical 4 12-05-2012 10:52 AM
Attic junctions Arky217 Electrical 3 02-13-2012 01:31 AM
Any codes or tips on too many water pipe junctions near panel? Red Squirrel Electrical 11 05-18-2011 11:20 AM
3-ways control half of a receptable bw777 Electrical 3 12-17-2010 08:39 AM
wiring: convert switched receptable to new light thatbradguy Electrical 1 10-12-2010 06:29 PM
