Junction For Too Many Conduit Turns? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 03:16 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Junction for too many conduit turns?
358.26 States: "There shall not be more than the equivalent of four quarter bends (360 degrees total) between pull points"
When a long run that requires more than 4 quarter bends, do I just add a small junction box, like a 4"x4" metal box for a piece of 3/4" EMT that has 3 - #6 running through it without junctioning.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-15-2008, 03:30 PM   #2
Electrician
Rewards Points: 802
You nailed it on the head. Once you have more then 360degrees of bend you need a junction box(or in this case a pull box). There is no need to make joints in here(you can if you want) it will just make it easirer for pulling.
darren is offline   Reply With Quote
Old 11-15-2008, 03:44 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
along with darrens advice, I add;
you do not have to wait until after 360 of bends. Engineer your work so the pull box is where it benefits you. The limitation is no more than 360 between pull points; there is no minimum.
Old 11-15-2008, 05:04 PM   #4
DIY'er
jamiedolan's Avatar
Thanks guys for the help. I will look for theose pull boxes and see what they cost. I have been using a lot of 4"x4" metal boxes that accept a 1/2" or 3/4" connection, I have been getting them for $2. I bet a pull box is easier to use with the additional space.
Jamie
Old 11-15-2008, 05:24 PM   #5
nap
You talking to me?
nap's Avatar
Jamie
a pull box is merely a term. Those boxes you have been using can be used as a junction box or a pull box. A pull box, or point, is merely someplace where you can pull the wire from or too.
You can continue to use those boxes or any sized box you want to use.
Old 11-15-2008, 05:26 PM   #6
Idiot Emeritus
Rewards Points: 1,492
Any type of box will do. You can use a 4 square, a single-gang handy box, even a 'C' condulet. When you connect the conduit to the box, if you make the two conduits in line with each other, you'll be able to pull the whole run straight through. This saves time, and eliminates the possibility of skinning the insulation off of the wires.
Rob
micromind is offline   Reply With Quote
Old 11-15-2008, 05:33 PM   #7
DIY'er
jamiedolan's Avatar
Oh ok, Good, Thanks. I just searched for Pull Box and saw some photos of these larger square boxes with a hinged cover that are about 8"x8" and 4" deep or so. I have seen many of them used in commercial.
Thanks for the clarification.
Jamie
Old 11-16-2008, 08:15 AM   #8
Electrician
Rewards Points: 802
pull box is just a term not an actual product.
Pull Box=Junction Box
Junction Box=Pull Box
Use one of your 4x4 and put it were it is most conveniant to you.
Conduit Fill and Derating jamiedolan Electrical 73 11-18-2008 11:36 PM
Use of unsheathed Romex NM-B wires in conduit? WoodworkerDave Electrical 10 09-29-2008 05:57 PM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 02:16 PM
Pvc Conduit bobo60 Electrical 1 11-14-2007 09:52 PM
