Junction Splicing - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-14-2014, 07:29 PM   #16
Rewards Points: 774
Originally Posted by cincinnati guy View Post
Thanks guys! I am no professional electrician.
Say it ain't so.
Know A Little is offline   Reply With Quote
Old 06-15-2014, 02:18 AM   #17
Rewards Points: 461
Originally Posted by Know A Little View Post
Say it ain't so.
Least I made it right, and not be like some and just leave it!
cincinnati guy is offline   Reply With Quote
Old 06-15-2014, 08:26 AM   #18
Rewards Points: 756
Better, but still a long way from "right".
1) Even though you went the two-box route, you still do not have the required 6" of free conductor.
2) You need a listed connector for tying the equipment grounding conductors together.
3) It appears that you wrapped the EGC the wrong way around the screw.
Mark
busman is offline   Reply With Quote
Old 06-15-2014, 12:09 PM   #19
Rewards Points: 455
Originally Posted by busman View Post
Looks like a hack-job extraordinaire. You asked.
Mark
I hear there is alot of hackwork going on in cincinnati
Cletis is offline   Reply With Quote
Old 06-15-2014, 03:18 PM   #20
Rewards Points: 461
Mark
I will make sure to use a wire nut on the ground, and will fix the twist on the one wire, I do see what your saying I see its twisted wrong. As for the 6" im curious why it has to be 6" and again I guess I need a tape measure and fix it.
Old 06-16-2014, 04:10 AM   #21
Rewards Points: 756
The requirement is at least 6" total length and at least 3" past the front of the box. The length is required to give working length even after a few reworkings of the box.
Let me say that you are a rarity in just accepting and fixing Code violations on this site. Most others ignore or try to argu their way out of them.
Mark
Old 06-17-2014, 01:38 AM   #22
Rewards Points: 461
Mark
The way I see it, if there are "Rules" they are there for a reason!
The Following User Says Thank You to cincinnati guy For This Useful Post:
Jim Port (06-17-2014)
Splicing Branch Circuit in Junction Box Question clegane Electrical 9 04-27-2014 11:47 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Was splicing to knob and tube outside a junction box ever legal? WillK Electrical 6 01-26-2011 12:50 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
Junction Boxes & Splicing Romex TX Recon Electrical 1 10-28-2009 04:28 PM
