Junction Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2008, 04:42 PM   #1
Junction Question?
Hi;
Does code allow me to run the following configuration:
Breaker > Outlet 1 + Pigtail in outlet box > outlet 2 + Pigtail in outlet box > Junction Box > Outlet 3, Outlet 4 (both from junction box)
For some reason, I suspect this is not allowed, but going to junction box first, then daisy-chain outlets is OK.
I can do either way, might end up with a junction box in a closet (which I don't like, but is probably OK as long as it's accessible)
Thanks for your input
FW
fw2007 is offline   Reply With Quote
Old 03-28-2008, 05:26 PM   #2
When is fishing season?
CowboyAndy's Avatar
It is perfectly acceptable as long as the junction box is TOTALLY ACCESSABLE.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-28-2008, 06:09 PM   #3
By totally accessible, I assume that means in a closet, etc as long as there is no permanent fixture/structure blocking access to it.
FW
Old 03-28-2008, 06:20 PM   #4
joed's Avatar
Rewards Points: 13,736
FW
Totally accessible means you can open it without smashing drywall or demolishing something to get to it.
Old 03-28-2008, 09:20 PM   #5
OK. So, you're saying that my feed can come first into an outlet box, have a pigtail with wires coming off for the outlet,. and continue on to a regular (4" square) junction box?
I think that the reasoning behind my question concerning the order of boxes comes from when we used to use the receptacle itself to make a daisy-chain splice.
While I understand this method is still allowed, I don't use it. I prefer to splice with wirenuts in the outlet box, and have only the two wires + ground going to the receptacle.
FW
Old 03-28-2008, 09:33 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Why wouldn't you continue from outlet to outlet without the jbox?
jbfan is online now   Reply With Quote
Old 03-29-2008, 09:23 AM   #7
You're right. It's kind of silly. I was just thinking that having a J-box in the attic would save 9' of wire for the outlets. Rethinking the concept, I will just go from outlet to outlet.
If I put a J-box in the attic, it needs to be on a main wall or a roof rafter, and that's going to add length to the wire run anyway.
FW
Old 03-29-2008, 09:56 AM   #8
joed's Avatar
Every point of connecton is a potential point of failure. The less joints the better. I prefer to make the connections on the receptacles. In Canada we count wire nuts in box fill.
Old 03-29-2008, 10:14 AM   #9
Knucklez's Avatar
Rewards Points: 942
only time i run to a junction box before distro is when pulling a main trunk a long long distance. for example, from panel in basement to attic is one wire and terminated in a junction box in attic. from this box to room just below attic is then distrobuted.
keep in mind that this attic junction must have >= 1meter space above box and be accessible.
i do this just incase there is a problem with the wiring in the room in the future... then i can just remove the one wire and don't have to remove the trunk which is a pain.
but.. every junction box = possible failure point as previous poster said. so you must weigh your options carefully.
Knucklez
Knucklez is offline   Reply With Quote
Old 03-31-2008, 10:56 AM   #10
Thanks for the heads up about 1m space above the J-box. I was thinking I could put one on the roof rafter, but I guess not. It would have to go on an outside wall.
I am going to just go from outlet to outlet instead.
FW
Old 03-31-2008, 11:03 AM   #11
jbfan's Avatar
Rewards Points: 650
In the US there is no requirment to keep the area clear for 1 meter. The j-box can be mounted to the top of the rafters if you choose.
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
wire junction code question wfischer Electrical 9 03-01-2008 09:21 AM
Junction Box Wiring Question mattbing Electrical 3 12-03-2007 10:49 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
