Junction Question?
Hi;
Does code allow me to run the following configuration: Breaker > Outlet 1 + Pigtail in outlet box > outlet 2 + Pigtail in outlet box > Junction Box > Outlet 3, Outlet 4 (both from junction box) For some reason, I suspect this is not allowed, but going to junction box first, then daisy-chain outlets is OK. I can do either way, might end up with a junction box in a closet (which I don't like, but is probably OK as long as it's accessible) Thanks for your input FW |
It is perfectly acceptable as long as the junction box is TOTALLY ACCESSABLE.
FW |
OK. So, you're saying that my feed can come first into an outlet box, have a pigtail with wires coming off for the outlet,. and continue on to a regular (4" square) junction box?
I think that the reasoning behind my question concerning the order of boxes comes from when we used to use the receptacle itself to make a daisy-chain splice. While I understand this method is still allowed, I don't use it. I prefer to splice with wirenuts in the outlet box, and have only the two wires + ground going to the receptacle. FW |
Why wouldn't you continue from outlet to outlet without the jbox?
If I put a J-box in the attic, it needs to be on a main wall or a roof rafter, and that's going to add length to the wire run anyway. FW |
Every point of connecton is a potential point of failure. The less joints the better. I prefer to make the connections on the receptacles. In Canada we count wire nuts in box fill.
only time i run to a junction box before distro is when pulling a main trunk a long long distance. for example, from panel in basement to attic is one wire and terminated in a junction box in attic. from this box to room just below attic is then distrobuted.
keep in mind that this attic junction must have >= 1meter space above box and be accessible. i do this just incase there is a problem with the wiring in the room in the future... then i can just remove the one wire and don't have to remove the trunk which is a pain. but.. every junction box = possible failure point as previous poster said. so you must weigh your options carefully. Knucklez |
Thanks for the heads up about 1m space above the J-box. I was thinking I could put one on the roof rafter, but I guess not. It would have to go on an outside wall.
I am going to just go from outlet to outlet instead. FW |
In the US there is no requirment to keep the area clear for 1 meter. The j-box can be mounted to the top of the rafters if you choose.
| All times are GMT -4. The time now is 01:39 AM. |
