Junction Boxes Under Blown-in Cellulose - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 11:29 AM   #1
the Musigician
DangerMouse's Avatar
Allowed?
Still considered accessible?
Do I need to 'flag' them?
What will the inspector expect?
Thanks! (once again)
DM
Old 09-19-2010, 01:39 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
allowed
acceptable
yes, still considered accessible
not desired if you are the electrician trying to find one
flagging is not required but a nice touch, especially if you are the electrician trying to find one.
Old 09-19-2010, 02:09 PM   #3
Chicago, IL
Michael Thomas's Avatar
As long as they have a listed cover, OK.
However:
1) Potentially a problem if connected older wiring listed for 60C rather than 90C, and now running hotter under the insulation.
2) Potentially a problem if no longer visible wiring and it's connection to the box is subject to damage when someone attempts to traverse the attic.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 09-19-2010, 02:17 PM   #4
the Musigician
nap:
Mike: Nope, all new wiring/12-2 so not a problem. Po)
This particular JB is for the smokers, 4 go into one box and all interconnect.
Back when I first installed them, it was easier this way than chaining them, believe me. However, now, I COULD have chained them.... if I wanted to rewire the whole thing..... I didn't.
DM
Old 09-19-2010, 05:39 PM   #5
nap
You talking to me?
nap's Avatar
just a note: wiring that runs within (I think Marc said it was 3 feet) of the scuttle into the attic must be protected either with conduit, through holes in the joists, or running boards along side the cable so you cannot step on them and damage them.
Old 09-19-2010, 06:21 PM   #6
the Musigician
I know, (but it's 6' I thought...) but my last wires are 7 or 8 feet away from where I plan on making the hole, so I'm good. Also, all of my wire is on runners up there, neatly taped, tied and stapled.
DM
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 08:40 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
Junction Boxes & Splicing Romex TX Recon Electrical 1 10-28-2009 04:28 PM
Mounting junction boxes in attic, are both of these locations acceptable? diymonkey Electrical 33 04-09-2009 07:24 AM
