Junction Boxes - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 08:21 PM   #31
Resi EC
Rewards Points: 252
Originally Posted by hidden 1 View Post
Back to original question...yes it has dining recepticles and a fridge on it .before fridge and outlets its junctioned again to bedroom outlets..is a 70s home also..
Is it required to be on dedicated circuit in dining room 20amp?
Sorry sbout that,
In todays codes the dining room is concidered a SABC, and the fridge can be on with the dining room (just AFCI protected).
I will also say that if its wired as said, you don't need to change it, (grandfathered in), but you can not add to it either
Gac66610 is offline   Reply With Quote
Old 06-08-2013, 09:06 PM   #32
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by Philly Master View Post
220.14 Other Loads All Occupancies. In all occupancies, the minimum load for each outlet for general-use receptacles and outlets not used for general illumination shall not be less than that calculated in 220.14(A) through (L), the loads shown being based on nominal branch-circuit voltages.
I assumed junction box here in this thread to mean outlets ..LOL
Section 220.14 applies only to those receptacles not covered by 220.12, Table 220.12 (read "a" and what it applies to under the table), see 220.14(J)1,2,3 which pretty much covers every receptacle and lighting outlet in the dwelling.
220.14 would however apply to the required GFI convenience receptacle installed at a pool for example.
There is no limit to the number of receptacles installed on a general lighting circuit in a dwelling. However, one 15A circuit is required for every 600 sq ft of living space, or one 20A circuit for each 800 sq ft of living space. A 2400 sq ft home would require four 15A circuits or three 20A general lighting circuits.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following 2 Users Say Thank You to electures For This Useful Post:
Jim Port (06-09-2013), stickboy1375 (06-08-2013)
Is difference between ceiling and attic for junction boxes? Mallethead Electrical 13 05-06-2013 08:20 PM
grounding metal junction boxes simanco Electrical 3 07-27-2012 05:22 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Number of junction boxes on a branch circuit j_sun Electrical 5 07-13-2011 09:37 AM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
