Junction Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 10:49 PM   #1
Rewards Points: 180
junction boxes
I have a 20 amp outlet w 12 gauge for outlets and wanted to know if there is a limit to how many junctions I can have on the circuit .I have it coming in to one room juctioned there,then going to another and juctioned to go in both directions in room like a Y .
.it ends there.
Is there any limit to these per circuit and do these effect furthest outlet at all?
Any info is appreciated.
hidden 1 is offline   Reply With Quote
Old 06-06-2013, 11:37 PM   #2
Rewards Points: 512
Depends on what they're used for. Kitchens, Dining Rooms, and Baths have special requirements, but other than that, no limit that I know of as long as the breaker is 20a and the wire is #12.
What are they used for?
Installation is the Reverse of Removal.
Old 06-06-2013, 11:50 PM   #3
Rewards Points: 180
Bedroom outlets.
Old 06-06-2013, 11:57 PM   #4
Rewards Points: 512
Should be fine, but why #12 and 20amp? Your choice, but I like #14 and 15a breakers.
Old 06-07-2013, 07:43 AM   #5
joed's Avatar
Rewards Points: 12,862
You didn't post your location so I will give the answer for CANADA.
I Canada you can as many junction boxes as you like as long as they remain accessible. They can not be buried under drywall.
You can only have 12 outlets on a circuit. Junction boxes and switches do not count as outlets.
Old 06-07-2013, 07:50 AM   #6
Rewards Points: 13,712
You need to go back and add your location to your profile if you want to ask code questions.
Just got to Quick links to edit.
Old 06-07-2013, 05:08 PM   #7
Rewards Points: 180
I already have a plenty of 12/2 and will be running seperate 20 amp circuits in other locations ,dedicated,so I have plenty of 12,the circuit I'm coming off of has 12/2 20 amp. I don't care to downsize to 15.I'm in Tn(as for code).
Thanks for info.
Old 06-07-2013, 06:50 PM   #8
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
if you are adding circuits ... 13 for 20 amp
220.14(I)
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 06-07-2013, 07:27 PM   #9
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
There is no limit to the number of junction boxes on any given circuit. But realize that every JB is another potential problem. We professionals very rarely use JB when installing new cabling. Also, there is no limit to the number of receptacles installed on a circuit in a dwelling unit.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
stickboy1375 (06-08-2013)
Old 06-07-2013, 07:31 PM   #10
Licensed electrician
Rewards Points: 1,612
220.14(I)
This does not apply to residental .
Old 06-07-2013, 07:33 PM   #11
220.14(I)
This does not apply to residental. You could have 200 receptacles on the circuit.
Old 06-07-2013, 07:36 PM   #12
Rewards Points: 516
220.14 Other Loads All Occupancies. In all occupancies, the minimum load for each outlet for general-use receptacles and outlets not used for general illumination shall not be less than that calculated in 220.14(A) through (L), the loads shown being based on nominal branch-circuit voltages.
I assumed junction box here in this thread to mean outlets ..LOL
Old 06-07-2013, 07:37 PM   #13
Rewards Points: 516
Old 06-07-2013, 07:38 PM   #14
Rewards Points: 516
220.14(I)
I stated "if you are adding circuits" .. so they would not have been in the original load calulations ...
Old 06-07-2013, 08:15 PM   #15
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,806
220.14(I)
MTN REMODEL LLC is online now   Reply With Quote
Is difference between ceiling and attic for junction boxes? Mallethead Electrical 13 05-06-2013 08:20 PM
grounding metal junction boxes simanco Electrical 3 07-27-2012 05:22 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Number of junction boxes on a branch circuit j_sun Electrical 5 07-13-2011 09:37 AM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
