Junction Box--Which Wire Goes To The Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-19-2012, 09:04 AM   #1
Rewards Points: 2,512
Junction box--Which wire goes to the outlet?
Can someone help me figure out which wire goes to my outlet.
Happy Thursday!!!
hammerlane is offline   Reply With Quote
Old 04-19-2012, 09:12 AM   #2
The HOT one! Also that should have a cover on it.:laughi ng:
antlerdancer is offline   Reply With Quote
Old 04-19-2012, 10:04 AM   #3
Learning Things Every Day
Jay 78's Avatar
My favorite color is red, so I'd say try the one with the red wire nut on it. By the looks of it, you'd have a 1 in 30 chance of it being the right one, and those odds aren't too shabby. As they say, close only counts in horseshoes and electrical work.
If that's not the right wire, just MacGuyver it with some new wire (speaker wire or a clothes hanger will be fine) and a wire nut or six - but make sure the wire nuts are red, because red is awesome. Don't listen to antlerdancer, you don't want a cover on that. The red and yellow wire nuts will make a pretty floral motif that's sure to impress the ladies - while demonstrating that you do indeed have a softer side - which will eliminate the need to shed a fake tear every time they drag you to a chick flick. It's a win-win situation.
Oh, one more thing.....
Under Construction
Jay 78 is offline   Reply With Quote
Old 04-19-2012, 12:04 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
How did you get a pic of my garage?
Old 04-19-2012, 12:20 PM   #5
Rewards Points: 150
I sure hope those splices were all pre-twisted. I would find a new location for the outlet and put drywall over that JB.
silversport is offline   Reply With Quote
Old 04-19-2012, 12:45 PM   #6
the Musigician
DangerMouse's Avatar
I THINK that box is a wee bit over it's allowed capacity.
DM
Old 04-19-2012, 03:19 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 852
Oh...I see the problem....they used the wrong color wire nuts....
Old 04-19-2012, 04:09 PM   #8
Rewards Points: 6,652
And no duct tape.
Old 04-19-2012, 06:17 PM   #9
Just a DIY guy
yeah, you can't risk an inspector finding it.
Who knew you could use a j-box as a breakerless sub-panel?
M3 Pete is offline   Reply With Quote
Old 04-19-2012, 08:35 PM   #10
Missouri Bound's Avatar
I'd like to see you try and put a cover on that.
Do you want it your way or the right way?
Old 04-19-2012, 08:36 PM   #11
You would have more room if you removed the wire nuts and used tape
Old 04-19-2012, 09:30 PM   #12
I=E/R
a7ecorsair's Avatar
The cable have to be stapled within 12 inched of the box
a7ecorsair is offline   Reply With Quote
Old 04-19-2012, 11:01 PM   #13
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Maybe we could fit a couple more in there and add some box extensions.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-22-2012, 08:34 AM   #14
does anyone know of the proper clamp for this??
Old 04-22-2012, 08:56 AM   #15
Rewards Points: 150
That is a first for me and I thought I had seen everything in the electrical field that was scary.
Jeeps is offline   Reply With Quote
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Wire for outlet? 12-2 or 12-3 Bahuffma Electrical 7 08-22-2011 06:02 PM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
wire ceiling fan to outlet switch((help)) tommy281 Electrical 10 11-02-2009 10:15 AM
