Junction Box In Stud Wall Behind Drywall? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 08:33 PM   #1
Junction box in stud wall behind drywall?
I'm trying to splice 12 gauge wire, can I use the liquid insulation glue they sell instead of a juction box? or If I have to use a junction box in the stud wall behind the drywall, If I just make sure the wirenuts are tight I shouldn't ever have to access it again right? I guess I could put it in the attic If I really have to.
bluemoonshine is offline   Reply With Quote
Old 03-23-2011, 08:35 PM   #2
Licensed electrician
Rewards Points: 1,744
All junction boxes must remain permanently accessible. They cannot be buried.
Old 03-23-2011, 08:41 PM   #3
Electrical Contractor
kbsparky's Avatar
Using things like "Liquid insulation glue" is one reason why circuits fail, and fires develop from jack-legged wiring.
Do NOT attempt such nonsense. ANY splices MUST be left accessible, so later on, when it fails, an electrician will be able to trace it down and repair it properly.
-KB
Old 03-23-2011, 08:42 PM   #4
I was kinda thinking that guess ill try crawl in the tiny attic.
Old 03-23-2011, 10:09 PM   #5
RST
DIY Homeowner
Rewards Points: 150
You could put a receptacle in the box. Might look funny depending on how high it is though.
I believe you could place a picture over the junction box cover to help hide it. Someone could simply remove the picture to access it.
Maybe you could run new wire back to the previous outlet?
RST
RST is offline   Reply With Quote
Old 03-24-2011, 07:30 AM   #6
Rewards Points: 6,652
They actually manufacture splice blocks that can be buried behind the wall. You may have to do a search on here, unless kbsparky can post brand.
Old 03-24-2011, 01:48 PM   #7
where? everywhere I search it says ALL splices must remain accessable.
do wirenut connections actually ever fail?
Old 03-24-2011, 01:57 PM   #8
Im splicing NM-B to UF cable anyway (cuz i have a bunch) so I don't think a splice block would work so well
Old 03-24-2011, 07:46 PM   #9
Scared Electrician
Saturday Cowboy's Avatar
yes wirenuts fail all the time.
I have never heard of any product that will allow you to bury a splice
you know that you could go all the way with UF right?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-24-2011, 07:54 PM   #10
Do it right.
I've seen them used on this old house on a huge modular house, they looked like the plug on a trailer for the lights.
SubSailor is offline   Reply With Quote
Old 03-24-2011, 08:03 PM   #11
Scared Electrician
If what you are talking about is what i think it is then i have done quite a bit of work with them. I spent 5 years in the mobile home industry. And they were notorious for problems, tho they were a favorite of the manufactures. They were installed under the home so they were accessible. I have not read the manufactures specs but if you could show me that the are allowed to be hidden then I would be convinced.
This old house is nothing but a hack!!
Old 03-24-2011, 08:27 PM   #12
kbsparky's Avatar
You mean this product by Tyco/Raychem?
-KB
Old 03-25-2011, 12:00 AM   #13
" Euro " electrician
frenchelectrican's Avatar
I have see them before but very limited use and myself I have really no use for those gimzos at all.
Just stay with the true and proven methold is a junction box and proper wirenuts and that will work good.
Merci.
Marc
Old 03-25-2011, 12:22 AM   #14
Rewards Points: 338
you'd think that after all these years, SOMEONE would have invented an NEC compliant splicing mechanism for in the wall burial and made millions. the whole idea of having to re-run a bunch of wire through walls and drywall as a result of a single splice is ridiculous. no wonder there is so much shoddy electrical behind so many walls.
NitroNate is offline   Reply With Quote
Old 03-25-2011, 12:28 AM   #15
I know there were couple manufacters do make them and there is only one I know of made that type of connector the last time I ran into I Just ditch them and use the proper junction box due the the last one I have see it got overheated and burnted the connection a bit.
Really the whole key thing is plan it right and route the cable or conductors in proper way to reduce the numbers of splices that one reason why I do it in proper way.
The last house in France I found over 30 hidden junction boxes took me a a bit to get all clear up { there were few major code volitatons show up as well }
Merci.
Marc
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Stud alignment in staggered wall rightit Building & Construction 5 03-17-2011 01:10 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Drywall mud on old painted block wall? urborn2die Drywall & Plaster 2 09-17-2010 08:54 PM
