Junction Box Problem? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2006, 01:45 PM   #1
I was replacing a light fixture and I noticed that my voltage tester would light up when I had one prong on the hot cable and another prong touching the metal box. Is this a problem? Does it mean that the box is not grounded?
bnvmorrow is offline   Reply With Quote
Old 09-20-2006, 02:19 PM   #2
They're all fixer-uppers
J187's Avatar
Rewards Points: 506
Actually, just the opposite. It means the box is providing acceptible ground for the hot lead to travel through the circuit you are creating. It means that the hot lead is hot and the box is a good ground.
Well, providing that its not actually a "voltage" meter thats "lighting up". I am guessing its a neon tester with a bulb that should light. It means everything is A-OK.
This is a way you might test for power before touching a wire, to make sure the circuit went out after you shutoff a breaker.
J187 is offline   Reply With Quote
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 09:08 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
