Junction Box Position In The Attic - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2013, 10:38 AM   #16
Rewards Points: 119
Hi,
While anxious to know if the connections are correct, I attach some pictures of the attic, the Canadian code for NB, with rule 12-3014 states that there must be at least 35,4 in vertical space above the junction box (head clearance).
Here some pictures:
Now, place the junction box on top of the joist is not easy has to get the 35.4 head clearance I would end up in the intersection with the diagonal brace.
Any place I can put the junction box above the 12in insulation?
For instance, I was thinking on the side of the diagonal brace (engineered truss?) but I am not sure this is allowed
Alex
Metallo is offline   Reply With Quote
Old 05-18-2013, 06:09 PM   #17
Rewards Points: 119
Hi all,
Can anybody look at the wiring in my post #14 and let me know if it is correct?
Alex
Old 05-18-2013, 06:23 PM   #18
Sparky
Rewards Points: 510
Black from cable 2 and 5 is connected to Red from cable #3
If you do this the timer will be controlled by the existing switch.
If you want the timer separate from the existing switch, but the black from cable 5 with the blacks from 1,3,4 and white from 2.
Techy is offline   Reply With Quote
Old 05-18-2013, 06:24 PM   #19
Sparky
Rewards Points: 510
Also, mounting anywhere on the trusses is acceptable
Old 05-18-2013, 07:01 PM   #20
Rewards Points: 119
Thank you much Techy,
Tomorrow I will try and report back the results
Alex
Old 05-19-2013, 07:20 PM   #21
Rewards Points: 119
Hi,
This is to report that the following connections are working fine for a light switch and the Leviton LTB60 timer:
  • White from cable 1+3+4+5+fan pigtailed together
  • Black from cable 1+3+4+5 and White from cable 2 pigtailed together
  • Red of the Timer connected to the Black of the fan
  • Black from cable 2 is connected to Red from cable #3
  • Bare ground= 1+2+3+4 + Green 5 and Green of the fan
Now it's time to work on the 6" duct
Thank you all for you precious help.
Alex
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
an attic fan AS a whole house fan? JLAMBERTI HVAC 2 06-21-2012 01:04 AM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Junction box in attic mjkiefer Electrical 3 09-06-2011 08:28 AM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 11:35 AM
