Old 12-13-2010, 04:26 PM   #1
Junction Box Placement?
Any code as to how far a junction box has to be from the entrance to an attic? I placed one about 12 inches from the opening to my attic. It was done out of convenience because I had a lot of wires servicing switches and lights fairly close to the attic opening. It was easy for me to hook things up while I stood on the ladder that I was using to get into the attic. Now I am concerned that there may be some code requirement regarding the placement of junction boxes.
jerseyguy1996 is offline   Reply With Quote
Old 12-13-2010, 04:51 PM   #2
unless wires and boxes are guarded 6' is required.
oleguy74 is offline   Reply With Quote
Old 12-13-2010, 08:41 PM   #3
What do you mean by "guarded"? Is that easy to do?
Old 12-13-2010, 08:44 PM   #4
2x4 blocking ect.just have to be protected from stepping on wires and boxes when entering attic crawl spaces.
Old 12-13-2010, 08:51 PM   #5
Does the fact that I mounted the box to the side face of the joist and not the top of the joist make a difference? It is still oriented with the cover plate facing up but it is screwed into the joist from the side. Not sure if I am explaining the mounting correctly. I will try to take a picture of it.
Old 12-13-2010, 09:16 PM   #6
just needs protection from being steeped on and dammaged.if with-in 6'
Old 12-13-2010, 09:21 PM   #7
Here is an image of the junction box in question.
Old 12-13-2010, 11:31 PM   #8
If that's within 12 inches of the attic hatch/door, it's a step/trip hazzard. Just because you know that it there and to avoid doesn't mean the next homeowner will. That being said, you could probably cover the area with a large piece of 3/4" plywood spanning the joists to protect the box.
clashley is offline   Reply With Quote
Wall oven junction box sizing and placement benjamincall Electrical 6 06-10-2010 11:39 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 10:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 12:03 PM
Junction Question? fw2007 Electrical 10 03-31-2008 12:03 PM
