Junction Box Mounting Screw Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 03:04 PM   #1
the Musigician
DangerMouse's Avatar
Junction box mounting screw question.
I've seen just about EVERY imaginable screw used to screw down junction boxes, but I'm wondering what ISN'T allowed? Anything? Usually I see panheads or drywall/deck screws, so I assume these are OK? Anyone?
DM
Old 07-30-2010, 03:56 PM   #2
Journeyman Wireman
Rewards Points: 150
It depends on what you are attaching the box to. Got to use the right screw for the right application. I wouldn't secure a 4 sq. box to drywall just using drywall screws. I would always use some sort of anchor to properly secure it.
Type of screws isn't addressed in the NEC but might be addressed in the UBC or spec'd out by the GC.
Jupe Blue is offline   Reply With Quote
Old 07-30-2010, 04:06 PM   #3
the Musigician
I know some boxes specify, and even INCLUDE certain screws. (fan rated octagon boxes, for example)
But for just the basic light fixture j/b to 2x4 on the ceiling, for instance, is there a specified fastener?
DM
Old 07-30-2010, 04:13 PM   #4
Journeyman Wireman
Rewards Points: 150
To be honest, I use whatever I have in my tool pouch at that minute. Mostly #10 x 1 1/4" square drive screws. But have been known to use 3/4" drywall, nails or whatever.
Old 07-30-2010, 06:35 PM   #5
Electrician
Proby's Avatar
I'll typically use 1" drywall screws to attach boxes to joists in basements or members in attics. I'll use 5/16" hex head sheet metal screws for attaching boxes to metal. It's really up to you.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 07-30-2010, 09:19 PM   #6
" Euro " electrician
frenchelectrican's Avatar
I am pretty much the same with other guys comment I use either nail or screw depending on what I have on hand and the way the box is set up for.
But for ceiling fan box useally automatic screw never nails unless it have ring shank on it that may be ok but not for all useage.
I like to use #10X1" with 5/16 hex that is most common one I use but there are other size as need if the situation called for.
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
