Junction Box From Hell - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 01:45 PM   #16
Bigplanz's Avatar
Rewards Points: 990
Maybe this guy's biased. Maybe the pictures are fake. Decide for yourself.
http://www.alwirerepair.com/burned_purples.htm
Bigplanz is offline   Reply With Quote
Old 03-06-2011, 02:30 PM   #17
Licensed electrician
Rewards Points: 1,622
From Ideal
http://www.idealindustries.com/media...compliance.pdf
Here is the MSDS, Material Safety Data Sheet
http://www.idealindustries.com/media...al-cu_msds.pdf
From the FAQs
http://www.idealindustries.com/media..._faq_sheet.pdf
FWIW wire nuts will also burn or melt when improperly applied to copper to copper connections.
Old 03-06-2011, 03:30 PM   #18
Originally Posted by Jim Port View Post
Neither the Ideal or Wagos is listed for use with aluminum.
Ideal 65 wire nuts are UL listed for Al wire.
joshxdr is offline   Reply With Quote
Old 03-06-2011, 03:39 PM   #19
UL says they are safe to use. The CSA says they are safe to use. My county electrical inspector says they are safe to use. But an electrician who offers a competing repair solution says they are not. Who are you going to believe?
Old 03-06-2011, 04:25 PM   #20
iminaquagmire's Avatar
Rewards Points: 338
AlumiConn's and the 65's will work if you pigtail the wires. Its really the only way besides getting rid of the existing aluminum wire. Either put in a bigger box or use an extension ring. Looks like you're missing a clamp on two of the cables too. As mentioned the Wagos and In-Shure connectors are not listed for AL/CU connections. Not suggesting you try it but I'd like to see that tested. I don't see why it wouldn't work. You don't have to worry about differing expansion or heat because they are not twisted together. My guess is at east for Ideal is that they didn't want to spend the money on a UL listing when they already have a product for this.
iminaquagmire is offline   Reply With Quote
Junction box and light switches travesty Electrical 3 01-18-2011 01:49 PM
Junction boxes for garage T8 fixtures mazeroth Electrical 13 01-25-2010 09:52 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
Light Fixture installed-no junction box? AdamsHouseCat Electrical 7 02-02-2009 11:03 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
