Junction Box Flush With Drywall - WHY? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 12:53 AM   #1
Junction box flush with drywall - WHY?
Why do most codes require junction boxes to be flush with the drywall, rather than say, flush with the stud?
I have a wall where the junction box is now set back by 1" because 1" of drywall was added (don't ask why).
Thanks,
David
djgrant is offline   Reply With Quote
Old 09-26-2011, 05:32 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
To decrease the risk of fire. Openings in combustible material have to be flush, non-combustible materials can be set-back upto inch.
Kyle
Old 09-26-2011, 07:33 AM   #3
Rewards Points: 1,548
There may not be a gap more than 1/4 inch between the rim of teh box and the cover (say flush with the wall surface), not filled by a mud ring or other approved box extension piece.
Old 09-26-2011, 10:01 AM   #4
Licensed electrician
Rewards Points: 1,876
There are box extensions available to solve your issue. Along with containing any arc or sparks, the box also supports the device. Without the box your only support for the device is the small ears that should be sitting on the finish surface of the drywall.
Old 09-26-2011, 10:13 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
Thanks,
David
If it were flush with the stud some yahoo would drywall right over it.
There are enough buried junction boxes without making it easy for them.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-26-2011, 11:20 AM   #6
I saw an extension at the hardware store but it was like 1.5" or maybe more. I need only 1" more. Any easy solution?
Thanks.
Old 09-26-2011, 11:40 AM   #7
Code05's Avatar
Rewards Points: 1,104
Single gang, double, or 4x4 box? Are there devices?
Code05 is offline   Reply With Quote
Old 09-26-2011, 11:42 AM   #8
Circular plastic box, I think the holes are 3.5" or 4" apart. It's a lighting fixture box, like the octagonal metal ones, but this is circular and plastic.
Old 09-26-2011, 11:46 AM   #9
Code05's Avatar
http://www.foxelectricsupply.com/con...ductNo=ARLBE1R
Old 09-26-2011, 11:47 AM   #10
Arlington makes extensions BE1, BE2 for on e anf 2 gang boxes, BE1R for round boxes. Should be available in an electrical supply house.
Old 09-26-2011, 11:49 AM   #11
Inspector/Instructor
codeone's Avatar
What you need is made by Arlington it is part #BE-1R.
codeone is offline   Reply With Quote
Old 09-26-2011, 11:52 AM   #12
codeone's Avatar
Arlington BE-1R
Old 09-26-2011, 12:17 PM   #13
I=E/R
a7ecorsair's Avatar
a7ecorsair is offline   Reply With Quote
Old 09-26-2011, 12:19 PM   #14
I=E/R
a7ecorsair's Avatar
Thanks.
The ring may look like it is 1.5" but it fits inside the box so it can fix up to about 1 1/4 set back.
Old 09-26-2011, 12:26 PM   #15
codeone's Avatar
Here are the specs for the Arlington BE-1R
For set back ceiling boxes. Fits 3-1/2" and 4" round or octagonal boxes.
Complies with 2002 NEC Article 314.20
Extends box up to 1-1/2" to bring it level with ceiling surface
Trims to accommodate shallow boxes or to avoid obstruction
Wall not Flush to hang drywall jburchill Building & Construction 14 06-22-2011 07:08 AM
In wall gutter downspout causing mold on drywall. chrispy35 General DIY Discussions 12 05-06-2011 10:35 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
